DeGriggs Posted August 23, 2016 Share Posted August 23, 2016 Alright here it goes 20 Moonclan Grots 20 Moonclan Grots 2 fanatics (one in each frog unit) Moonclan Shaman Orruk Warboss (with banner) 10 Orrucs with bows 10 orruks with bows 30 orruks with double axes Basic idea is to jam the grots up the front, using fanatics to ****** up the opponents charging and movement. The 2 now units are all about objective camping and support. The large orruk unit is the hammer, having the buffs and manpower to hold up bigger targets. The shaman is a cheap mystic shield battery, applying arcane bolts when needed What do you guys think? Link to comment Share on other sites More sharing options...
Poddy Posted August 23, 2016 Share Posted August 23, 2016 Looks solid. Would try to look into getting war machines. Also The Moonglan Warboss (old skarsnik model) is fantastic value for 60 points Link to comment Share on other sites More sharing options...
Orruk'sPizza Posted August 23, 2016 Share Posted August 23, 2016 Very low attacck power. Problem with bravery, if you buff the orks, the grots excape very fast.. The orcs with bows bring a very low number of wounds.... You need something big and strong Like troll, gore grunta etc... Aos were played with several elite units, if you play against stormcaster, its hard to wounds them. Mhhh...... Link to comment Share on other sites More sharing options...
