Selborg Posted July 2, 2019 Share Posted July 2, 2019 the general is given an additional command ability, to activate this ability must occupy a command point or not? Quote Link to comment Share on other sites More sharing options...
0 Fert Posted July 2, 2019 Share Posted July 2, 2019 If it is a command ability, not a command trait, then you must spend 1 command point to activate the ability. Your General can use the standard command abilities from the main rules and the new GHB 2019 at a 12" range, while other heroes can use them at a 6" range. Again, you will spend 1 command point each time you use a command ability. Quote Link to comment Share on other sites More sharing options...
Selborg
1 answer to this question
