vorathian Posted September 25, 2017 Share Posted September 25, 2017 As I understand things you can not pile in after you are already in base contact, is this true? Because that would make the dead-watch battalion for flesh eater courts a lot less potent than I originally thought. Link to comment Share on other sites More sharing options...
BaldoBeardo Posted September 25, 2017 Share Posted September 25, 2017 3 minutes ago, vorathian said: As I understand things you can not pile in after you are already in base contact, is this true? Because that would make the dead-watch battalion for flesh eater courts a lot less potent than I originally thought. Correct. #toptip: You don't *have* to move into contact to attack. And even if you're already in contact, you can still attack even if you don't pile-in, as per the combat phase. Link to comment Share on other sites More sharing options...
vorathian Posted September 25, 2017 Author Share Posted September 25, 2017 So this does let you attack two separate times in your turn? Thats simply awesome. Thank you. Link to comment Share on other sites More sharing options...
vorathian
2 answers to this question
