Going First or Second as FEC
Cagos
Depends on your list like Thanatos said.
I find that if you go first, you need to be super aggressive. Put your ghoul patrol in offensive positions and go for broke. Unfortunately I've done the opposite in most of my games when taking the first turn. Every time my opponent has double turned me and done a large amount of damage onto my non ghoul patrol models, which are far less regenerative.
Also first/second turn depends on the scenario. 3 places of power is a great place to take first turn as FEC, ghoul patrol can clog up one side of the board while your big flappys can hold the middle point. this way you make it quite tough for your opponent to dislodge you (I generally run terrorgheist and ZD with ghoul kings, 4+ 5+ 5+ is really difficult to dislodge off of a place of power). In other scenarios going for the first double turn may be better, ultimately deploy safely and take advantage of ghoul deployment and the big beasties speeds to position yourself nicely for a charge, and a huge advantage if you get a double.
