Ghoul king on terrorgheist question
pikachoux
As above. In matched play summoning models onto the field count towards your max roster points (i.e. In a 2000pt roster if you have 2000pts deployed at game start you cannot use the command ability for the entire game) in open play use it every turn (depending on agreed pregame ideas with opponent)
I think this is what you might be getting at: if you have a unit of models on the board that are killed and removed, can the same unit of models be used to represent a new unit (providing you have the summoning points)? Or do you need seperate models? - is that more or less the question?
If so, I don't see why anyone would take issue with it.
Sent from my SM-G920F using Tapatalk
you can use the very same models but they count as a new unit and you need the points resummoning them. even if you play it as "resurrecting slain units", every unit that leaves the fields and comes back later counts as a new unit (same with ring of immortality artefact).
