Amradiel Posted March 29, 2017 Share Posted March 29, 2017 Greetings. I would like some help with a 1000p Khorne army. I just own the Bloodbound miniatures from the Age of Sigmar starter. I was thinking of using The Lord, Bloodsecrator, reavers and bloodwarriors. Then what? One thought was Bloodletters and a Slaughterpriest Link to comment Share on other sites More sharing options...
raketjan Posted March 29, 2017 Share Posted March 29, 2017 Hi! I'm having a lot of fun with the starter set battalion (Goreblade warband) and just fleshing it out a little... If you add 10 Bloodreavers, 5 Bloodwarriors and 5 Skullreapers you end up with exactly 1000 points, and a 2 drop army if you want to decide who goes first. or alternatively skip the reavers and take 5 Wrathmongers instead of the Skullreapers... The Goreblade warband is really nice, making your charges a bit less likely to fail. And if you remember it, the extra attack if a unit is wiped out is never bad. I never remember it though... good luck Link to comment Share on other sites More sharing options...
Jharen Posted March 29, 2017 Share Posted March 29, 2017 You can't go wrong with adding Wrathmongers to that force. Adding more attacks to your current models and they can be used as a threat to any high wound/high damage monster models your opponent may field. Link to comment Share on other sites More sharing options...
Amradiel Posted March 31, 2017 Author Share Posted March 31, 2017 Maybe buy the Battleforce then? Link to comment Share on other sites More sharing options...
