Zhorphorus Posted February 25, 2017 Share Posted February 25, 2017 Hi guys!! I was wondering if anyone knows of some great techniques to achieve thick snow for bases? I'm going to be basing both models and wyldwoods (citadel woods) and was wanting a really thick blizzard effect. I was going to try to implement drifts into it as well If you have any photos of what it comes out like that would be awesome! Thanks guys! Link to comment Share on other sites More sharing options...
Kuma Posted February 25, 2017 Share Posted February 25, 2017 Baking soda and elmer's glue makes a great thick paste Link to comment Share on other sites More sharing options...
DemonWolfkin Posted February 26, 2017 Share Posted February 26, 2017 Caster sugar and PVA glue. Mix until so it is fairly thick but still runny. If needs be add white paint and mix as well.Apply to bases and leave to dry.Sent from my SM-G930F using Tapatalk Link to comment Share on other sites More sharing options...
HeadHunter Posted February 26, 2017 Share Posted February 26, 2017 If you're using baking soda, be sure to put in a drop or two of white paint, otherwise it will yellow with age. Better to use scenic snow, as it will not dissolve in water, and white glue rather than the standard PVA. Also, you might still want to put some scenic features like small rocks or tufts of dead grass - a broad expanse of snow on a base can look monotonous otherwise. Link to comment Share on other sites More sharing options...
ZealousJ Posted February 26, 2017 Share Posted February 26, 2017 I experimented with decorators caulk bases recently and whilst it didn't get the results I wanted it did occur to me that it could make decent snow bases with a little work. Link to comment Share on other sites More sharing options...
Totzro Posted February 26, 2017 Share Posted February 26, 2017 I really dig GWs new snow texture paint. I've used a mixture of pva glue and snow flock for good results as well previously Link to comment Share on other sites More sharing options...
Zhorphorus Posted February 27, 2017 Author Share Posted February 27, 2017 Wow thanks guys! So many ideas I hadn't thought of! @Totzro is the top image the new Valhallan blizzard texture paint? Link to comment Share on other sites More sharing options...
Turragor Posted February 27, 2017 Share Posted February 27, 2017 37 minutes ago, Zhorphorus said: Wow thanks guys! So many ideas I hadn't thought of! @Totzro is the top image the new Valhallan blizzard texture paint? I think so. The results from it are really good. Comes out looking like: Link to comment Share on other sites More sharing options...
Totzro Posted February 27, 2017 Share Posted February 27, 2017 Yes the Skaven is based with Valhallan Blizzard texture paint, I'm super impressed by it! Link to comment Share on other sites More sharing options...
HeadHunter Posted February 28, 2017 Share Posted February 28, 2017 I like the fluffy texture of the snow on the Khador Battle Mechaniks. Is that also the Valhallan Blizzard, or something else? Link to comment Share on other sites More sharing options...
Veillotron Posted February 28, 2017 Share Posted February 28, 2017 @Turragor: this looks really good. Quick question: when sticking the model to the base, do you use super glue, super glue + pins or do you scrape off some of the paint and use plastic glue? Link to comment Share on other sites More sharing options...
Turragor Posted February 28, 2017 Share Posted February 28, 2017 7 hours ago, Veillotron said: @Turragor: this looks really good. Quick question: when sticking the model to the base, do you use super glue, super glue + pins or do you scrape off some of the paint and use plastic glue? Thanks. I usually superglue and pin models to a base when I prep them separate yep. Link to comment Share on other sites More sharing options...
Durant Posted February 28, 2017 Share Posted February 28, 2017 I paint my models on a pin, then do the base, when all is done I super glue the model pin and base together, I just drill a hole in the base and put a pin covered in super glue to it. Link to comment Share on other sites More sharing options...
Veillotron Posted February 28, 2017 Share Posted February 28, 2017 @Durant and @Turragor: thank you gents for confirming! Link to comment Share on other sites More sharing options...
Durant Posted February 28, 2017 Share Posted February 28, 2017 Just plan the base, foot with the pin should touch some surfece so you can't see the pin. Link to comment Share on other sites More sharing options...
