Making Archaon Viable with Tzeench Fatesworn Warband
Solvanic
Posted
Hi guys,
After a lot of reading and research I have come up with this list to try to make my big Archaon viable. Tzeench gives him some nice advantages, mainly getting his spell of choice from either lore as well as using destiny dice (6s are really good on Slayer of Kings). All 10 units are Tzeench and Mortal, so they will all benefit from the 4 Fatemaster's command abilities. Having 4 fatemasters mean my chances of getting the lower numbers to reroll very significant (1-4 are way better than 5-6). In an ideal situation every model could reroll 1s,2s,3s and 4s on hits, wounds, charges, armor saves, archaons # of attacks and D6 damage! Every unit but Archaon takes full advantage of the (-) to (-1) rend from the formation. This is a VERY fast army (Fatemasters move 16, Archaon 12, Gorebeasts 8).
Now where I need help. Suggestions! I am heavily considering running only 3 fatemasters, and using those points for more bodies? Would have to replace with another mortal Tzeench unit because I am at the minimum for the fatesworn battalion. I am also very interested in trying to run arcanite cabal as well, but I am fairly sure units cannot be part of more than 1 formation? Any other thoughts also appreciated :)
Leaders
Fatemaster (140)
Fatemaster (140)
Fatemaster (140)
Fatemaster (140)
Archaon (700)
- General
Battleline
10 x Chaos Warriors (180)
- Halberd & Shield
- Halberd & Shield
10 x Chaos Marauders (60)
Units
1 x Chaos Gorebeast Chariots (100)
Battalions
Fatesworn Warband (120)
Total: 2000/2000
Posted
Alternative list (although I would have to buy more chariots) that includes the cabal formation! This gives me 3 more spells of Tzeench which I feel like might be worth it, although all the fatesworn lose their rend. What do you all think?
Leaders
Fatemaster (140)
Fatemaster (140)
Fatemaster (140)
Archaon (700)
- General
Battleline
Units
Battalions
Arcanite Cabal (50)
Posted
Tbh. Archaon is too expensive at anything less than 3000 points. Much more suited to 4-5k games than 2k.
He leaves your army too vulnerable to dying and just leaving him alone to them be swarmed.
Posted
What about something like this?:
Archaon 700
Fatemaster 140
Fatemaster 140
Gaunt summoner 100
Chaos lord on daemonic mount tz mark 140
10 marauder tz mark 60
10 warrior, hand and shield, tz mark 180
10 warrior same as above 180
3 gorebeast chariots, tz mark, great weapon 300
2000 points, u have a very strong deathstar, gorebeasts with +1 to hit and -1 rend are brutal. Also destiny dice could help with charge rolls, making they explode attack more frequently. I thinm gaunt summoner is the strongest mage for 100 point.
Finally you have slightly more bodies and meatshields for ur centerpieces.
It's just a thrown idea, but i think it can be pretty effective.
Posted
And a third list without the fatesworn warband!
Leaders
Fatemaster (140)
Fatemaster (140)
Fatemaster (140)
Fatemaster (140)
Fatemaster (140)
Archaon (700)
- General
Battleline
10 x Tzaangors (180)
Units
Battalions
Arcanite Cabal (50)
Total: 1990/2000
Posted
You think Archaon will be too easy to kill? Even with all of his rerolls?
Posted
Archaon 700
Fatemaster 140
Fatemaster 140
Gaunt summoner 100
I like this list, but I dont think Archaon is worth taking with only 2 fatesworn, I think its gotta be at least 3. Why take the lord on daemonic mount? His command ability doesnt seem like it will be very useful unless you are going to group the gorebeasts? In which case they are far less tactically useful in my opinion. Also the Marauders and gorebeasts are not nearly as effective without the fatesworn battalion which I dont think you have included here?
Posted
Are you including the battalion cost into the lists ? It's like 120 isn't it ?
An you can't use traits with archaon as general, and non named heroes can only use items.
Posted
Wooooops mb, make 1 warrior unit a marauder and there u have the points. Lord helps gorebeast to be killy
I will be sincere, i don't like fatemasters at all, i think that for these points u can take way more useful things, like sorcerer, gaunt, for 20 points more u have ogroid. I understand that they kinda work well with archaon, but i still don't like them (i mean, they do little damage) they save well, but what 's the point in taking them? How are u gonna match up against a skaven/sayl list? U just get blown up.
The good thing into taking the lord is that u can count on another unit in order to do damage, the gorebeasts, which can deal an impressive amount of damage. Archaon isn't enough to win the game, simply because u bringing more heroes to make it worth, u make the whole army squishier
Posted
An you can't use traits with archaon as general, and non named heroes for items.
Ya the costs of the battalions are right there in the posts. I know Archaon cant use traits but the Fatemasters can still use items I am pretty sure.
Posted
In the first list the fatesworn will all have rend-1 to both attacks which will help their killiness a bit. I also think all the rerolls will mean almost everything will be rerolling all failed armor saves. The reason I am taking fatesworns is to take advantage of Archaon. The rerolls are hard to mathammer but with 4 fatesworn its fair to assume everyone will reroll 3/4s of their saves?
Posted
There's definitely scope for a list here. However spamming an overpriced hero (the Fatemaster) who isn't a wizard (and Fatesworn doesn't make him a wizard) is unlikely to be the answer.
As much of a big part of Archaon's appeal is his command ability spam, the fact that he is a Tzeentch Mortal and Daemon allows him to take (I believe) a choice of either a Lore of Fate or Lore of Change spell (i.e. not both). Many of these are amazing with Archaon as the Caster (as is someone else casting Shield of Fate or the spell that grants +1 attack to one weapon on him). Due to the rule of one, you are not going to benefit much from the theoretical arcane bolt spam.
I would fill the Battalion with cheaper heroes a few units of Marauders and a unit of Warriors (18 as various people object to deploying a unit of 9 and I cannot be bothered to have the highly complicated argument every game). You need bodies to make up for the point sink that is Archaon to be competive in the Battleplans.
Posted
2 minutes ago, Nico said:
There's definitely scope for a list here. However spamming an overpriced hero (the Fatemaster) is unlikely to be the answer.
As much of a big part of Archaon's appeal is his command ability spam, the fact that he is a Tzeentch Mortal and Daemon allows him to take (I believe) a choice of either a Lore of Fate or Lore of Change spell (i.e. not both). Many of these are amazing with Archaon as the Caster (as is someone else casting Shield of Fate on him). Due to the rule of one, you are not going to benefit from the theoretical arcane bolt spam.
Thanks for the response! I'm not sure Archaon's cost can be justified if you're not using his command ability? What heroes would you recommend?
Posted
I just mean use one of them and maybe a Lord on Daemonic mount or even a Lord of Chaos (gives another reroll saves of one buff), rather than using 4 140 point heroes. What you want are wizards (or you can summon a LoC...).
Posted
I've been considering something similar to what Nico's been saying - potentially using a few command abilities with Archaon, but mostly getting some mileage out of him through the spells.
Leaders
Archaon (700)
- General
Chaos Lord On Daemonic Mount (140)
Gaunt Summoner of Tzeentch (120)
Fatemaster (140)
Battleline
- Hand Weapon & Shield
10 x Pink Horrors Of Tzeentch (140)
Units
10 x Chaos Knights (400)
- Chaos Glaives
Total: 1960/2000
Archaon would have the spell to give himself +1 to hit and wound (I imagine that works with destiny dice?), another could potentially have the spell to give slayer of kings an extra attack. Fatemaster and lord can use their command abilities and follow the big block of knights who are a huge tarpit,  and the gaunt summoner (on disc for extra fluffiness) could follow Archaon around.
Not a huge amount of models or wounds - and no ranged - so it wouldn't be super competitive but could be kind of fun.
Posted
Leaders
Archaon (700)
- General
Fatemaster (140)
Battleline
Units
- Chaos Glaives
Total: 1960/2000
+1 to hit and wound is definitely the way to go I think, as it makes slayer of kings even more dangerous. I really appreciate your and @Nico, @shadowgra advice to not overdo the fatemaster. What do you all think of this list?
Leaders
Archaon (700)
- General
Fatemaster (140)
Gaunt Summoner (100) (probably glimpse of future or Arcane transformation ?)
Fatemaster (140)
Battleline
- Halberd & Shield
- Halberd & Shield
- Halberd & Shield
Units
Battalions
Fatesworn Warband (120) (Gives -1 rend to basically all weapons except a few of Archaon's, I think this is pretty huge for the viability of all the units)
Total: 2000/2000
Posted
Like it more than the other lists. Although i still think that a list like that is really squishy, you have less than 50 bodies, and even if warriors have 5++ save, they won't do much in terms of offensive.
What about dropping mortals and fatesworn and go really heavy on magic? Loc can be pretty good since he boosts casting rolls, plus archaon throws in 2 spells each turn. In the end magic has more offensive power than any mortal list u will ever make as tzeentch.
I would go something like: archaon, loc, gaunt, some pink horrors as a core. Then u can fill the remaining points with basically everything u need: skyfires, tzaangors, warriors (?), marauder as chaff, sayl, stormfiends too. The benefits of going magic heavy is that multiple units in your army are big threaths, not only archaon. Also a lord of chaos can help him to survive more, with rerolling save of 1
Posted
Quote
Leaders
Archaon (700)
- General
Fatemaster (140)
Fatemaster (140)
Battleline
- Halberd & Shield
- Halberd & Shield
- Halberd & Shield
Units
Battalions
Total: 2000/2000
Looking better.
I don't see the value of Gorebeast Chariots personally (1 model for objective purposes). As you may not be able to deploy units of Warriors as 9 models (minimum unit size being stuck on a totem, not worth the argument every second game) - I would buff up at least one unit of Warriors to 20 (18 models) - Halberds are fine. Tick the 10 total units with Marauders and if you can nudge up the Gaunt Summoner to the one with the familiars (+1 cast as I recall) for 20 points and consider a summoning pool of 100 (for the Balewind Vortex so you have a partial counter to Kunning Rukk Arrer Boyz).
Posted
Have you tried the 320p archaon on horse. He also has the same abbilities as the 700p guy just not the dragon. I think hes kinda solid anyway and still get to use his sword against enemies. I know its not optimal but it frees up alot of points :)
Posted
ya but I have the big one painted up really well and he's awesome so I'm trying to make a list with him.
