Overread Posted February 16 Share Posted February 16 Greetings all, I require the talented services of those who have beastmen models, a ruler and perhaps a camera and some other GW models. I'm after some scale and dimension info and the only thing I can get from the GW website is the base sizes for models. So if you've got some models and want to help out I could do with the following: 1) Measurements of each model. Things like the height (foot to eye); width; length; weapon length; arm length etc... Basically whatever you can give. 2) Photos comparing beastmen to other armies - Daughters of Khane, Slaves to Darkness, A Space Marine. This is purely so I can compare with what I currently own and have a rough idea/reference point outside of the measurements. Quote Link to comment Share on other sites More sharing options...
Lord Krungharr Posted February 17 Share Posted February 17 Will measuring old metal models help? I do have plastic Dragon Ogors, Cygors, and a Ghorgon though. Quote Link to comment Share on other sites More sharing options...
Overread Posted February 23 Author Share Posted February 23 Old stuff and new works, at least if the old stuff is comparable in size to the new models that replace them. So if its just more of a material change that's fine; but if the difference is more like the Space Marines to Primaris its less useful. Quote Link to comment Share on other sites More sharing options...
CrimsonKing Posted February 25 Share Posted February 25 On 2/16/2022 at 3:42 PM, Overread said: Greetings all, I require the talented services of those who have beastmen models, a ruler and perhaps a camera and some other GW models. I'm after some scale and dimension info and the only thing I can get from the GW website is the base sizes for models. So if you've got some models and want to help out I could do with the following: 1) Measurements of each model. Things like the height (foot to eye); width; length; weapon length; arm length etc... Basically whatever you can give. 2) Photos comparing beastmen to other armies - Daughters of Khane, Slaves to Darkness, A Space Marine. This is purely so I can compare with what I currently own and have a rough idea/reference point outside of the measurements. Might be able to sort you out tomorrow EST Quote Link to comment Share on other sites More sharing options...
Kramig Posted February 26 Share Posted February 26 (edited) Edited February 26 by Kramig Quote Link to comment Share on other sites More sharing options...
The Red King Posted February 26 Share Posted February 26 Hmmm I got some cheap secondhand dragon ogors that were made with old metal bloodletter bodies but I'm starting to think they don't have the real dragon ogor bodies either because those look so much bigger than mine... maybe I'll proxy them as centigor. Quote Link to comment Share on other sites More sharing options...
Overread Posted February 27 Author Share Posted February 27 Thanks @Kramig looks like the ungors are much smaller than I thought at only about 1inch tall. Where to the gors fit in? Similar size to the Ungor or the Bestigors? Quote Link to comment Share on other sites More sharing options...
Kramig Posted February 27 Share Posted February 27 Gor are very similar to bestigor. I'll try to make a picture with them (maybe in a better quality) Quote Link to comment Share on other sites More sharing options...
