Spifferson Posted September 2, 2016 Share Posted September 2, 2016 Are unit fillers a thing of the past? Ive been thinking of doing a couple of 2 model bases as I expand on my units of 10. For 25mm infantry I would mount 2 on a 40mm. And 32mm I would mount 2 on a 50mm. I am coming at it from a modelling perspective with little scenes worked in but I would appreciate your thoughts. Link to comment Share on other sites More sharing options...
Bjarni St. Posted September 2, 2016 Share Posted September 2, 2016 Yeah for tournaments they could be a hard sell. Even if you keep them generally in the back you'd often end up with them in/near contact and it's very much not the same thing getting 2x 25mm bases into contact as 1x 40mm. In friendly games and with big units (thinking 30-40ish) you could let it slide though. Link to comment Share on other sites More sharing options...
daedalus81 Posted September 3, 2016 Share Posted September 3, 2016 Mostly a thing of the past. Units are generally smaller anyway. Someone will come up with a good idea eventually though. Link to comment Share on other sites More sharing options...
Shadowspite Posted September 3, 2016 Share Posted September 3, 2016 In regular AoS games, where the bases are ignored and you measure from the models, you're ****** yourself over (in a rather minor way) by limiting how close together you can position your troops. But I'd say go for it if it looks cool. In tournament games where you have to measure from the base and use the 'correct' base for each model, it would presumably not be allowed. If you don't play in tournaments with strict basing rules (I don't!), then that is not a problem, of course. Link to comment Share on other sites More sharing options...
Lucifer Posted September 3, 2016 Share Posted September 3, 2016 Get some skirmish movement trays to clump models together - then they're removable when you need them to be... Link to comment Share on other sites More sharing options...
pforson Posted September 3, 2016 Share Posted September 3, 2016 1 hour ago, Shadowspite said: ...If you don't play in tournaments with strict basing rules... Is there such a thing? I'm going to Warlords in a week and as far as I can tell there are no strict basing rules for that. At least, I hope not, as some of my Skaven Clanrats are multi-based due to looking cool! Link to comment Share on other sites More sharing options...
The Jabber Tzeentch Posted September 3, 2016 Share Posted September 3, 2016 You would probably be better using oval bases as it would represent a similar size compared to large rounds. But to be honest as cool as they might look you will get questioned on it here and there, especially if there's a chance that it could make a viable difference it combat. Link to comment Share on other sites More sharing options...
Shadowspite Posted September 3, 2016 Share Posted September 3, 2016 3 hours ago, pforson said: Is there such a thing? I think so? The whole tournament scene is largely a foreign country to me, though. No idea about Warlords specifically. Link to comment Share on other sites More sharing options...
AGPO Posted September 3, 2016 Share Posted September 3, 2016 I think they still have a place as proxies and features that add to the aesthetic of a unit. What will hopefully disappear is the large generic rock counting as ten goblins/clanrats/skinks. Things like including a gravestone with a hand bursting out for a unit of skeletons or a mortal succumbing to Nurgle's rot to a unit of plague bearers would work perfectly in Age of Sigmar IMO. Link to comment Share on other sites More sharing options...
Sleboda Posted September 3, 2016 Share Posted September 3, 2016 On 9/2/2016 at 4:29 PM, Spifferson said: Are unit fillers a thing of the past? Oh...my...SweetZombieJeebus!!!! Thank you for that post. I had not thought of that, but even if I had not been an AoS fan before, this would have tipped me over the edge. I hated, hated, hated, hated, hated...despised...hated unit fillers. Ding dong that witch it dead and burned. Hallie-freekin-looya! Link to comment Share on other sites More sharing options...
Spifferson Posted September 4, 2016 Author Share Posted September 4, 2016 Thanks for the responses so far. I definitely am glad that I am not needing to do this to fill out a huge block of troops but rather choosing to add a couple thematic pieces to larger units. Link to comment Share on other sites More sharing options...
Lucio Posted September 4, 2016 Share Posted September 4, 2016 I'd be unhappy with an opponent who turns up with a miniature with multiple models on a single base who counted it as anything other than 1 miniature of it's kins Anything else and it's too easy to game to your advantage Link to comment Share on other sites More sharing options...
pforson Posted September 4, 2016 Share Posted September 4, 2016 2 hours ago, Lucio said: I'd be unhappy with an opponent who turns up with a miniature with multiple models on a single base who counted it as anything other than 1 miniature of it's kins Anything else and it's too easy to game to your advantage How so? If for instance, in a 40 strong clan rat unit, 3 rats are based on 1 oval base for aesthetic reasons, would that be an advantage? Link to comment Share on other sites More sharing options...
Bostian Posted September 9, 2016 Share Posted September 9, 2016 I started a Deathrattle army, and I like the idea of clumping together several skeletons on an oval base--6 models on 25mm bases, for example, seem to take up about the same real estate as 6 models on a 52mm x 90mm oval base (pic below). Especially for a standard bearer or centerpiece of the unit, I like the idea of creating something a bit more scenic than just models on a movement tray. (And moving 40 individual skeleton warriors takes a fair bit of time.) Link to comment Share on other sites More sharing options...
Double Misfire Posted September 9, 2016 Share Posted September 9, 2016 16 minutes ago, Bostian said: I started a Deathrattle army, and I like the idea of clumping together several skeletons on an oval base--6 models on 25mm bases, for example, seem to take up about the same real estate as 6 models on a 52mm x 90mm oval base (pic below). Especially for a standard bearer or centerpiece of the unit, I like the idea of creating something a bit more scenic than just models on a movement tray. (And moving 40 individual skeleton warriors takes a fair bit of time.) Nope, just nope go play 9th Age. If you want to make scenery, go make awesome scenery for your models to climb and fight over. Where would you even start measuring from, the individual models (unable to move), or would you just call all six in range if you could get the base within 1"? Link to comment Share on other sites More sharing options...
Double Misfire Posted September 9, 2016 Share Posted September 9, 2016 The only acceptable unit filler: Link to comment Share on other sites More sharing options...
Bostian Posted September 10, 2016 Share Posted September 10, 2016 17 hours ago, Double Misfire said: Where would you even start measuring from, the individual models (unable to move), or would you just call all six in range if you could get the base within 1"? You're right, measuring for pile in and close combat would be problematic, although every time I've played with big units I can never manage to pile in and roll for attacks for every model until most of the unit has been removed as casualties... and then it's too late to do any good. The main reason to build this Death army is for a garage game I host on Halloween night--my wife gives out candy and my local game group plays at a table in the garage. This is never going to see the tabletop in a tournament. And for fun games like this I think unit fillers could be cool. Link to comment Share on other sites More sharing options...
Double Misfire Posted September 10, 2016 Share Posted September 10, 2016 Oh ok, in that case maybe try to get ahold of some of these? Link to comment Share on other sites More sharing options...
Paul Conti Posted September 11, 2016 Share Posted September 11, 2016 I think its fine as long as you make sure youre not breaking movement rules by accident. Probably want ro make sure your opponent/TO is cool with it. Bases technically dont matter, but model movement and spacing does. Link to comment Share on other sites More sharing options...
pforson Posted September 12, 2016 Share Posted September 12, 2016 I had 2 clanrats in a unit of 40 this weekend on oversized bases, because they were converted and needed more space. Not a single opponent even bated an eyelid. I even got a few positive comments. Link to comment Share on other sites More sharing options...
MechaBriZilla Posted September 12, 2016 Share Posted September 12, 2016 On 9/9/2016 at 4:02 PM, Double Misfire said: Nope, just nope go play 9th Age. If you want to make scenery, go make awesome scenery for your models to climb and fight over. Where would you even start measuring from, the individual models (unable to move), or would you just call all six in range if you could get the base within 1"? Don't you think this is a little over-critical? I mean seriously, you're ready to send the guy to 9th age purgatory over unit fillers??? In all seriousness though, why not use a filler like this? You just drop the filler unit in somewhere in the middle or back of the unit. When you start taking casualties that get over the filler unit size, pull it out. Most of the units you'd want a filler for are going to be in hordes like the skellies, and are going to be chewed up pretty fast anyway. AS for measuring, He has them on their normal bases, attached to a larger base, problem solved. Larger base doesn't count for measuring. Just measure too/from the model base, not the oval. Link to comment Share on other sites More sharing options...
Double Misfire Posted September 12, 2016 Share Posted September 12, 2016 48 minutes ago, MechaBriZilla said: Don't you think this is a little over-critical? I mean seriously, you're ready to send the guy to 9th age purgatory over unit fillers??? In all seriousness though, why not use a filler like this? You just drop the filler unit in somewhere in the middle or back of the unit. When you start taking casualties that get over the filler unit size, pull it out. Most of the units you'd want a filler for are going to be in hordes like the skellies, and are going to be chewed up pretty fast anyway. AS for measuring, He has them on their normal bases, attached to a larger base, problem solved. Larger base doesn't count for measuring. Just measure too/from the model base, not the oval. Blah, sorry, was doing my best to be funny with sarcasm in that post. I'd never condemn anyone to 9th Age in real life! Link to comment Share on other sites More sharing options...
MechaBriZilla Posted September 12, 2016 Share Posted September 12, 2016 18 minutes ago, Double Misfire said: Blah, sorry, was doing my best to be funny with sarcasm in that post. I'd never condemn anyone to 9th Age in real life! It's that whole tone/text thing... Sorry. and here I thought you were working for satan for a second there.... Link to comment Share on other sites More sharing options...
Double Misfire Posted September 12, 2016 Share Posted September 12, 2016 I only work for Malal sir. Link to comment Share on other sites More sharing options...
