Hitting on abilities and abilities to re-roll success's
Maddpainting
I swore it was in a faq but couldn't find.
If you have a rule to have a rule take effect on a hit that stops the attack (Example, Scourgerunner Lay the Beast Low; hitting on a 6 stops the attack and instead deals X MW's) but your opponent has a rule that yes re-roll successful hits (like Archaon's The Eye of Sheerian; hits of a 6 needs to be re-rolled).
Does the attack still need to be re-rolled?
EDIT: Adding warscrolls to easily visualize the rules
https://www.games-workshop.com/resources/PDF/AoS_Warscrolls/aos_Archaon_eng.pdf
https://www.games-workshop.com/resources/PDF/AoS_Warscrolls/aos_scourgerunnerchariots_eng.pdf
Edited by Maddpainting
4 answers to this question
  • 1
The answer is actually on page one of the Core-Rules. Re-Rolls, last sentence:
Quote
Rules that refer to the result of an 'unmodified' dice roll are referring to the result after any re-rolls but before any modifiers are applied.
So re-rolls have priority over other abilites.
Edited by EMMachine
Answer this question...
