awkd Posted August 28, 2016 Share Posted August 28, 2016 For those of you that have converted ogors into big orcs/orruks what orc heads did you use? the regular orruk heads would be too small I assume. Thanks Link to comment Share on other sites More sharing options...
Flogger Posted August 28, 2016 Share Posted August 28, 2016 I'd probably use heads from Spellcrow, Kromlech or Maxmini for that. Link to comment Share on other sites More sharing options...
Furious Posted August 28, 2016 Share Posted August 28, 2016 I use Nob heads - large 40k Orks, if you are unfamiliar. They are the perfect size, and you can choose bare headed or with helmets that fit Sigmar aesthetic. 'Ard Boys helmets are a good size, too, if you want to go that route. Link to comment Share on other sites More sharing options...
Lucio Posted August 28, 2016 Share Posted August 28, 2016 Ogryns convert into Orruk / Ironjawz models better, and you can even use the Ogryn gasmask heads as a basis for an Orruk head too. Other than that, Ork Nob heads, most Kromlech heads (they're larger than GW in most cases), and Spellcrow's "bulky" head options, all of which have been suggested above, work well. Once my local store's birthday is over, hoping to have some models to show the idea, as realising that since I want to take part in Armies on Parade, I can't make my Orruk Ironjawz "yoof" models just yet, and thus my Battleline will have to be some Ironjawz super-soldiers (Ogors armed with Ironfists), and a Moonclan Grot detatchment (to justify my Warboss's squigs!) Link to comment Share on other sites More sharing options...
awkd Posted August 28, 2016 Author Share Posted August 28, 2016 Thanks everyone. I am working on a mostly greenskinz army an planning on having some ogors as a battleline unit that can add some punch too but would prefer if they looked like bigger orcs. will look at nob heads and the other options suggested. Thanks again. Link to comment Share on other sites More sharing options...
Papapene Posted August 28, 2016 Share Posted August 28, 2016 I tried that, the heads are just too small. The only ones I could get to fit were ard boy heads and they still looked out of place. Check out mmimzies post about his Ogre slaves Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
Lysandestolpe Posted August 29, 2016 Share Posted August 29, 2016 I use the nob heads, I like that they are slightly smaller because it makes them look a little bit more oddly mishapen. I wanted them to look like they were regular orruks that were morphed with the ogors using magic. However, The awkwardness I also countered by using a lot of iron jaws built out of .20mm thick Plasticard. That makes the illusion that they look bigger. good luck! Link to comment Share on other sites More sharing options...
awkd Posted August 29, 2016 Author Share Posted August 29, 2016 Thanks @Lysandestolpe, the back story for your ogors is very similar to what I was thinking. My extra weird Weirdknob grew himself some extra large orc bodyguards to do his dirty work. Once I get my ogors I'll see if I can get some Nob heads and maybe the bulky Spellcrow ones and see if I like how they look. I'm not opposed to just having some regular ogors in my army either, just thought the look of the army would be better if they were all orcs. Thanks again for all of the suggestions. Link to comment Share on other sites More sharing options...
Chris Tomlin Posted August 30, 2016 Share Posted August 30, 2016 @Cowboy Boots Matt did an Orcre army back in 8th and is currently working on some Ogorruks for AoS. He has used a huge variety of Orruk and 40K Ork heads on his, so I am sure can weigh in with some solid advice. Also, he knows a thing or two about nobheads. Sorry...couldn't resist a nob head joke after reading it about 50 million times in the above posts!! Link to comment Share on other sites More sharing options...
Chipatola Posted December 25, 2017 Share Posted December 25, 2017 Do ogor head fit nicely with the ironjawz brutes models ? Link to comment Share on other sites More sharing options...
Vasshpit Posted December 26, 2017 Share Posted December 26, 2017 13 hours ago, Chipatola said: Do ogor head fit nicely with the ironjawz brutes models ? I personally find them a little too big for my taste. Ironjawz brutes heads are closer in size to 40k boyz heads. However this is not a bad thing as it truly gives you many more options for heads. With the launch of AoS, I've noticed Orcs (Orruks) models becoming more proportional and not so apeish. Link to comment Share on other sites More sharing options...
Chipatola Posted December 26, 2017 Share Posted December 26, 2017 I try to make an ogor themed destruction army, and i want to include brutes. Hopefully I will find a way to convert these orruks into heavy armored ogors (Looking forward to see any picture showing some headswap of an orruk brutes and ogor Link to comment Share on other sites More sharing options...
Kessler Posted December 26, 2017 Share Posted December 26, 2017 I think Savage Orruks heads are the biggest - they seem way off on Brutes, for example. I don't have swapped heads picture, but here's a picture with ogor standing beside savage orruks, maybe it helps. Link to comment Share on other sites More sharing options...
