Mindstealer sphiranx and chaos lord of chaos on karkadrak
Tizianolol
I asked your question on the TTS discord and here's the response I got so far.
"karkadrak is there with a 3d model even, just not in the slaves box, i found it randomly on one of the scenario tables i loaded in ^-^
no idea about sphiranx tho, but i believe they are both on 90mm oval bases
90x52mm to be exact"
If they post anymore info i'll get back to you with it. :)
On 7/13/2020 at 10:19 PM, Tizianolol said:
Guys i dont find that models on tabletop simulator,  what unit i can use with same size to covert? Thx all for helps!!:)
Check the basing size chart on warhammer community. Should be easy enough to find a proxy that way 👍
