Plauge Drone Flying stand problem
Rozza the dogga
Good morning gents,
I've recently been putting together a box of those beautiful plauguedrone models and I've found that when following the instructions for the banner bearer the model it's so close to the ground (even with the longest flying stand) there is no room to put the stinger in his tail.
Does anyone know what has caused this?  Have I built it wrong?  Do I have the wrong flying stand in the box?
If not, does anybody have a workaround?
Thanks.
Hmm... weird. I do remember it touching after I finished basing but i believe there was still room for the stinger. You should be good just building it, worst case it touches the base and pushes the model up a touch. You can still glue everything together without issue.
  • 3 weeks later...
  • 4 weeks later...
