Acid_Nine Posted June 8, 2020 Author Share Posted June 8, 2020 Long time, no post again! I have been building the base of the temple and finished it two days ago, and now I get to work on the roof and the floor. Gotta make the final hyish symbol for it, paint it gold, and finish painting the rest of this thing before I work on the hill. Also found a better way to make flock. Turns out, adding a generous heap of PVA glue allows it to be made into finer stuff, which helps it fit in with the scale of the figures. Will put some on my skeletons soon just to show it off. also, I have plans on using the excess stuff I scraped off of the molding. Turns out, if I crush it with a hammer and apply it to a sheet of cardboard or foam core, I can make a gravel road. Not the fanciest, but it works well I think. Will show more pictured later. Quote Link to comment Share on other sites More sharing options...
Acid_Nine Posted June 16, 2020 Author Share Posted June 16, 2020 Took me a bloody while but I finally finished the ‘roof’ portion of this temple, which will be different to the mountain temple I have planned. A bit more cramped than I first thought it would be, but so far everything is looking right for this. Spray painted the terrain and will soon be dry brushing the ****** out of it, and then it’s time to work on the hill / cliff leading up to it... then base the undead attacking the base and hopefully work on the elves. 4 Quote Link to comment Share on other sites More sharing options...
Acid_Nine Posted June 21, 2020 Author Share Posted June 21, 2020 Getting that preorder today motivated me to do the most tedious part... drybrushing the pillars. And I did it. I finished my second temple, in all it’s glory! Now to start working on the display board... 3 Quote Link to comment Share on other sites More sharing options...
Acid_Nine Posted June 24, 2020 Author Share Posted June 24, 2020 Got all the pink foam I need, and already drew the layout of my board with basically the outline I want, and I decided to ditch the hill idea for the much, much easier cliffside ideas. I will probably do the cliffsides in a sandstone like color to make it different from the granite ish stone. The first stone temple is going to be on a lower level, and the main temple is on the highest cliff, both with stairs leading up to it. Also painted three spirit hosts because I want to get back to painting figures, and test out my grass on a much wider base! 2 Quote Link to comment Share on other sites More sharing options...
Acid_Nine Posted July 25, 2020 Author Share Posted July 25, 2020 Long time no update! Summer rad tech school has been killing me, so I haven’t been able to really do a lot of hobbying, especially since the paints I wanted to use didn’t come in. They did, and after playing around with the color scheme I finally finished my ziatrec high warden, the first lumineth model I painted, using retributor gold with chameleon paints burning gold colorshift on top of that, some differently shaded areas on the model, and some colorshift on the shield. Pretty happy how it turned out! 2 Quote Link to comment Share on other sites More sharing options...
Sttufe Posted September 8, 2020 Share Posted September 8, 2020 Nice job, best lumineth I have seen so far! Quote Link to comment Share on other sites More sharing options...
LuminethMage Posted September 18, 2020 Share Posted September 18, 2020 How is this going @Acid_Nine ? You painted some more Lumineth? Quote Link to comment Share on other sites More sharing options...
