Been looking through the forum and Google and, while some discussion of combining these two endless spells exist, it's always about whether the MWs are inflicted on the first or second portal, and I'm fairly certain it's on the former.
My question, however, is as follows: Predatory endless spells are moved after setting them up. Now, the wording on the Spellportal clearly states that, if an endless spell ends within 6" of one side, you can take it and set it up on the other side. So, if you do this with the Pendulum, does this new set up mean you technically get another fresh move? Since you are setting up the endless spell, not moving it?
Aethervoid Pendulum - Slicing into Reality: When this model is set up, the player who set it up can immediately make a move with it.
Umbral Spellportal - Arcane Passage: If a predatory endless spell finishes a move within 6" of an Umbral Spellportal model, remove it from the battlefield and set it up again anywhere within 6" of the other Umbral Spellportal model from this endless spell.
Edit: Thinking about it, RAW this makes full sense, but RAI it's ridiculous since it opens up a combo of infinite MWs, so I'm gonna guess it's a no can do.
Gistradagis
Edited by GistradagisLink to comment
3 answers to this question
