1) "After the Shadow Geminid model has moved, each unit
that has any models it passed across suffers D3 mortal
wounds. In addition, subtract 1 (to a minimum of 1)
from the Attacks characteristic of melee weapons used
by each unit that has any models it passed across until
the end of the battle round. A unit is not affected by
the Shadow Geminid model if it has been passed across
by the Light Geminid model earlier in the same battle
round. After the Light Geminid model has moved, each
unit that has any models it passed across suffers D3
mortal wounds. In addition, subtract 1 from hit rolls
for each unit that has any models it passed across until
the Light Geminid model if it has been passed across by
the Shadow Geminind model earlier in the same battle
round (a unit can be affected by one or other of the
models each battle round, but not both).’
That means if a unit is been passed across by both takes only only one malus and only 1d3 MW right?
2) ‘If a Wizard successfully casts a spell while they are
within 1" of an Umbral Spellportal model, the range and
visibility of the spell can be measured from the other
Umbral Spellportal model from this endless spell. After
the range and visibility for a spell has been measured
from an Umbral Spellportal, you cannot use the Arcane
Passage ability again for that Umbral Spellportal in
that phase.
If a predatory endless spell finishes a move within 6"
of an Umbral Spellportal model, remove it from the
battlefield and set it up again anywhere within 6" of the
other Umbral Spellportal model from this endless spell.
After an endless spell finishes a move within 6" of an
Umbral Spellportal and is set up again, it cannot move
again in that phase, and you cannot use the Arcane
that phase.’
So if I want to send a predator endless spell through the spellportal I have to cast the endless spell next to the wizard and AFTER move it across the portal and leave it within 6" the portal?if it's like that that's not so good I imagine.
Alessio
I have two questions:
that phase.
that phase.’
Thanks!
1 answer to this question
