NoMaDhOoK Posted December 12, 2019 Share Posted December 12, 2019 (edited) AoS Statshammer: Over the last month, in my free time, I have been building a website that allows you to add units -> weapon profiles (with modifiers) and it will calculate the average damage that unit would do against various saves (2+, 3+, 4+, 5+, 6+, -). If you are interested in checking it out, the current URL for it is https://aos-statshammer.herokuapp.com/ Github repo: https://github.com/damonhook/aos-statshammer A reminder that there is a lot more to a unit than just their damage output. This is a tool, not a definitive answer of which unit is better Note: I am going to keep this thread updated with release notes. Current features include: Ability to add up to 5 different Units, with up to 8 profiles each Ability to add up to 5 modifiers per profile Results are in the form of a table, line chart, bar chart, and radar chart Dark Theme Ability to use dice values where applicable (e.g: D3, D6) Persistent storage for theme and units so a refresh won't lose all of your data Import / Export of unit data Export stats (table and graphs) to PDF Ability to add modifiers to target (e.g: Reroll 1's to save, FNP, ethereal, etc.) Planned Features include: More modifiers An actual domain name Ability to add modifiers to the unit as a whole (instead of just to each profile) Ability to optionally add points values to unit to give an average damage / 100 points for better comparisons Other notes: If you do this sort of math in your free time, and you notice that something is not right, please do let me know The repo is public, so you are free to contribute through PR's or creating issues for feature requests/bugs Edited January 31, 2020 by NoMaDhOoK 13 6 7 Quote Link to comment Share on other sites More sharing options...
TheCovenLord Posted December 12, 2019 Share Posted December 12, 2019 Small things. There is no reroll of anything less than total rerolls (ie no option for rerolls of 1 to hit) Also if you add conditional modifiers it results in an error "Failed to Fetch Stats" Otherwise very cool tool. Just makes me sad to see the true output of some of my units haha 1 Quote Link to comment Share on other sites More sharing options...
NoMaDhOoK Posted December 12, 2019 Author Share Posted December 12, 2019 (edited) 8 minutes ago, TheCovenLord said: Small things. There is no reroll of anything less than total rerolls (ie no option for rerolls of 1 to hit) Also if you add conditional modifiers it results in an error "Failed to Fetch Stats" Otherwise very cool tool. Just makes me sad to see the true output of some of my units haha Thanks for checking it out and giving feedback There should be 3 separate modifier options for rerolls (reroll, reroll failed, and reroll 1s). Conditional modifiers are very new (since this afternoon). Maybe there is some combination that causes the error. If possible could you let me know the configuration you tried so I can replicate it Edited December 12, 2019 by NoMaDhOoK Quote Link to comment Share on other sites More sharing options...
Rune Posted December 12, 2019 Share Posted December 12, 2019 48 minutes ago, NoMaDhOoK said: AoS Statshammer: Over the last month, in my free time, I have been building a website that allows you to add units -> weapon profiles (with modifiers) and it will calculate the average damage that unit would do against various saves (2+, 3+, 4+, 5+, 6+, -). If you are interested in checking it out, the current URL for it is https://aos-statshammer.herokuapp.com/ Github repo: https://github.com/damonhook/aos-statshammer A reminder that there is a lot more to a unit than just their damage output. This is a tool, not a definitive answer of which unit is better Current features include: Ability to add up to 5 different Units, with up to 8 profiles each Ability to add up to 5 modifiers per profile Results are in the form of a table, line chart, bar chart, and radar chart Dark Theme Ability to use dice values where applicable (e.g: D3, D6) Persistent storage for theme and units so a refresh won't lose all of your data Import / Export of unit data Planned Features include: More modifiers An actual domain name Ability to add modifiers to the unit as a whole (instead of just to each profile) Export stats (table and graphs) to PDF Ability to add modifiers to target (e.g: Reroll 1's to save, FNP, ethereal, etc.) Ability to optionally add points values to unit to give an average damage / 100 points for better comparisons Other notes: If you do this sort of math in your free time, and you notice that something is not right, please do let me know The repo is public, so you are free to contribute through PR's or creating issues for feature requests/bugs This is currently running on the free tier of Heroku, I may need to upgrade it, but will see I have attached an example comparison between Poleaxes and Broadaxes for Hearthguard Berzerkers. Awesome! Can't wait for you to add the points element for better comparison! Quote Link to comment Share on other sites More sharing options...
Mutton Posted December 12, 2019 Share Posted December 12, 2019 Awesome. I anticipate spending a lot of time with this thing. Quote Link to comment Share on other sites More sharing options...
TheCovenLord Posted December 12, 2019 Share Posted December 12, 2019 (edited) 2 hours ago, NoMaDhOoK said: Thanks for checking it out and giving feedback There should be 3 separate modifier options for rerolls (reroll, reroll failed, and reroll 1s). Conditional modifiers are very new (since this afternoon). Maybe there is some combination that causes the error. If possible could you let me know the configuration you tried so I can replicate it Make a unit of 3 models with 2 attacks each. 4+ to hit 3+ to wound -2 rend 3 damage with conditional modifier 6 to hit is an additional wound that is what generated the Stats Fetch Error. Its definitely the conditional modifier generating an extra damage on 6's to hit or wound causing it (it caused it whether the 6 was to hit or to wound). As for the reroll ones I had to scroll down on the menu to find it so my bad it does exist which is fantastic! loving the tool so far Edited December 12, 2019 by TheCovenLord Quote Link to comment Share on other sites More sharing options...
NoMaDhOoK Posted December 12, 2019 Author Share Posted December 12, 2019 (edited) 1 hour ago, TheCovenLord said: Make a unit of 3 models with 2 attacks each. 4+ to hit 3+ to wound -2 rend 3 damage with conditional modifier 6 to hit is an additional wound that is what generated the Stats Fetch Error. Its definitely the conditional modifier generating an extra damage on 6's to hit or wound causing it (it caused it whether the 6 was to hit or to wound). As for the reroll ones I had to scroll down on the menu to find it so my bad it does exist which is fantastic! loving the tool so far Awesome, thanks for the info. I'll dig into it some more tomorrow *Edit:* I can't replicate it in chrome. But got it replicated on Samsung browser. I think it is an incompatibility with some browsers I'll try get it all fixed up over the weekend. Thanks again. Edited December 12, 2019 by NoMaDhOoK Quote Link to comment Share on other sites More sharing options...
BaylorCorvette Posted December 12, 2019 Share Posted December 12, 2019 Amazing. Thanks for sharing! Quote Link to comment Share on other sites More sharing options...
The_Dudemeister Posted December 13, 2019 Share Posted December 13, 2019 (edited) All the features it already has are working perfectly! Can't wait for the updates, this will be my go-to tool for sure. Can you already rearrange the 5 units or is it always dependant on which unit's profile you created first? If so, I'd like that feature added. Edited December 13, 2019 by The_Dudemeister Quote Link to comment Share on other sites More sharing options...
NoMaDhOoK Posted December 13, 2019 Author Share Posted December 13, 2019 41 minutes ago, The_Dudemeister said: All the features it already has are working perfectly! Can't wait for the updates, this will be my go-to tool for sure. Can you already rearrange the 5 units or is it always dependant on which unit's profile you created first? If so, I'd like that feature added. Re-arranging is something I plan on adding very soon. Quote Link to comment Share on other sites More sharing options...
Eevika Posted December 13, 2019 Share Posted December 13, 2019 Damn thats nice. Definitely better than other i have used Quote Link to comment Share on other sites More sharing options...
Planar Posted December 13, 2019 Share Posted December 13, 2019 (edited) Thats fantastic. Thank you very much for your effort and generosity to share this minor observations for feaure update: -couldn't add D3+1 damage to weapons -save + print feaures would be really nice to have Edited December 13, 2019 by Planar 1 Quote Link to comment Share on other sites More sharing options...
Eevika Posted December 13, 2019 Share Posted December 13, 2019 Is there a way to put an attacks characteristic of 2d6 for example? Quote Link to comment Share on other sites More sharing options...
NoMaDhOoK Posted December 13, 2019 Author Share Posted December 13, 2019 20 minutes ago, Eevika said: Is there a way to put an attacks characteristic of 2d6 for example? Not in the released build at the moment. To get the equivalent you can do d6 for attacks and add a bonus attacks modifier of another d6. In the branch I am currently working on I am added the functionality for 2d6 or d6+2 etc. So it shouldn't be long Quote Link to comment Share on other sites More sharing options...
The_Dudemeister Posted December 13, 2019 Share Posted December 13, 2019 2d6 is 7, so putting that in the number of attacks makes it easier for now. 1 Quote Link to comment Share on other sites More sharing options...
NoMaDhOoK Posted December 13, 2019 Author Share Posted December 13, 2019 (edited) So after gathering some feedback from this thread, reddit (and mentions in other threads). The current plan for the next 2 releases are as follows: Release 0.4.0 (the next one) [RELEASED] Full dice notation (e.g: `d3`, `2d3`, `3d6+2`, etc.) Reordering of units, profiles, and modifiers (Buttons for now, draggable will come later, once I have got through some of the more important changes) Graph axis labels Ability to switch between tabbed graphs, and a graph list for Desktop This is to make screenshots much easier until the next release, where I will tackle exporting as PDF Extra modifiers that are identified between now and then Some dark mode improvements to increase visibility (there is a dark mode currently, but it has some visibility issues) Release 0.5.0 [RELEASED]: Ability to export results as PDF, containing the following items Unit configuration Stats Table All 3 Graphs Extra modifiers that are identified between now and then Dark mode out of "beta" Edited December 19, 2019 by NoMaDhOoK Released 0.5.0 now 3 Quote Link to comment Share on other sites More sharing options...
NoMaDhOoK Posted December 14, 2019 Author Share Posted December 14, 2019 (edited) Version 0.4.0 has now been released (see above post for full details). Along with the following bug fixes: Use React.memo and _.isEqual to avoid unnecessary re-renders when props Ensure that attacks, and damage characteristics never go lower than 1 Fix a safari specific bug which caused the modifier inputs to change order when their values changed Move from deprecated @babel/polyfill -> core-js and regenerator-runtime This was a larger release so please do let me know if anything looks off. FYI: @Planar, @Eevika this means you can now do proper dice notation Lastly, I have noticed that most screenshots seem to be of the bar graph, so I am attaching a poll for whether the graph order should change: https://www.strawpoll.me/19084784 Edited December 14, 2019 by NoMaDhOoK 1 2 Quote Link to comment Share on other sites More sharing options...
Osprey07 Posted December 14, 2019 Share Posted December 14, 2019 Love this!! Cant wait for updates! Quote Link to comment Share on other sites More sharing options...
Lord Krungharr Posted December 14, 2019 Share Posted December 14, 2019 Does it take into account if models are painted, or being played with for the first time? That always seems to affect the dice rolls! 1 Quote Link to comment Share on other sites More sharing options...
Lord Krungharr Posted December 14, 2019 Share Posted December 14, 2019 Wow, based on the graphs I should probably give my Chaos Knights ensorcelled weapons. Though my Legion of Azgorh Bull-Centaurs slightly edge even the charging-lances out in terms of damage. That's all without buffs though. Slaves to Darkness get more buffs. Quote Link to comment Share on other sites More sharing options...
Scurvydog Posted December 15, 2019 Share Posted December 15, 2019 This is a great tool, makes it much easier to get an accurate overview of more complicated units like stormcast concussors with riders getting 1 mortal wound in addition on 6 to hit, while the mount gets d6 damage instead of 1 on 6s to wound and this tool can handle that. Thank you for making this, great work. Quote Link to comment Share on other sites More sharing options...
Sev Posted December 15, 2019 Share Posted December 15, 2019 Thanks for sharing it! It's awesome. How would you encode the D3 or D6 on hit?ex: balistas & co Quote Link to comment Share on other sites More sharing options...
NoMaDhOoK Posted December 15, 2019 Author Share Posted December 15, 2019 (edited) 1 hour ago, Sev said: Thanks for sharing it! It's awesome. How would you encode the D3 or D6 on hit?ex: balistas & co If you are talking about the celestar ballista. You use the "exploding" modifier. Since the ability is d6 instead of 1 (and not D6 extra like most others). Just set the extra hits parameter to D6 - 1 Edit: this image is incorrect as I read the warscroll incorrectly. See my post below for updated Edited December 15, 2019 by NoMaDhOoK Incorrect info Quote Link to comment Share on other sites More sharing options...
Sev Posted December 15, 2019 Share Posted December 15, 2019 (edited) Hmm Seems like result ain't good... are you sure about it? D6-1 on 6 to hit doesnt sound right Edited December 15, 2019 by Sev Quote Link to comment Share on other sites More sharing options...
NoMaDhOoK Posted December 15, 2019 Author Share Posted December 15, 2019 (edited) 29 minutes ago, Sev said: Hmm Seems like result ain't good... are you sure about it? D6-1 on 6 to hit doesnt sound right Ahh, You are right, I read the warscroll wrong. It's not on a 6. It's on any hit. You should be able to do D6 - 1 on a {the hit roll} (so 5 for rapid fire, 3 for single). Edit: I've attached examples of the 2 types of shots. The math does look correct by my quick calculations but I'll triple check and add it as a test case for the repo. Edited December 15, 2019 by NoMaDhOoK Added examples Quote Link to comment Share on other sites More sharing options...
