I am struggling to find a clear answer anywhere about this. Do I retain control of an objective if I move away from it? Move battle reports I watch on youtube, everyone seems to keep units on objectives even if they are not in danger of being stolen. The rules state:
"At the end of each player’s turn, you must check to see if either player has gained control of any objectives. To do so, you and your opponent must count up the number of models you have within 6" of the centre of each objective; you gain control of an objective where your count is higher than your opponent’s count.Once you gain control of an objective, it remains under your control until the enemy is able to gain control of it.A model can only be counted towards gaining control of one objective per turn. If one of your models could be counted towards gaining more than one objective, you must pick which one they are counted towards that turn."
To me this sounds like once I have taken an objective, even if I move away from it I still control it for the whole game, unless the enemy takes it.
Dolio
Hi,
"At the end of each player’s turn, you must check to see if either player has gained control of any objectives. To do so, you and your opponent must count up the number of models you have within 6" of the centre of each objective; you gain control of an objective where your count is higher than your opponent’s count. Once you gain control of an objective, it remains under your control until the enemy is able to gain control of it. A model can only be counted towards gaining control of one objective per turn. If one of your models could be counted towards gaining more than one objective, you must pick which one they are counted towards that turn."
What is correct here?
Thanks!
3 answers to this question
