John E Posted July 3, 2019 Share Posted July 3, 2019 If you play a 2 v 2 match and both the players on the same side use Khorne, do they each benefit from the same blood tithe pool? Quote Link to comment Share on other sites More sharing options...
1 King Taloren Posted July 3, 2019 Share Posted July 3, 2019 No you each should have your own blood tithe points to work with. Especially with how they work in games it would be a huge handicap to have to use the same pool considering that using points spends them all at once. 1 Quote Link to comment Share on other sites More sharing options...
0 Vextol Posted July 15, 2019 Share Posted July 15, 2019 (edited) On 7/3/2019 at 7:48 PM, King Taloren said: No you each should have your own blood tithe points to work with. Especially with how they work in games it would be a huge handicap to have to use the same pool considering that using points spends them all at once. I don't think it's specified officially anywhere but I recall reading that in almost all tournament environments, pools are shared (and yes, it is a huge handicap for everyone but seraphon). Edited July 15, 2019 by Vextol Quote Link to comment Share on other sites More sharing options...
0 BrocknerTheBear Posted July 15, 2019 Share Posted July 15, 2019 At the recent throne of skulls doubles we had to share a single bloodtithe table so the team as a whole got a bloodtithe point for units destroyed not one per player. This was listed in the tournament pack. But the battletome itself makes no obvious reference to what would happen I believe. Quote Link to comment Share on other sites More sharing options...
0 Charleston Posted July 15, 2019 Share Posted July 15, 2019 Actually I can´t find the rule that defines how we get Bloodtithe anywhere in my BT Quote Link to comment Share on other sites More sharing options...
0 John E Posted July 18, 2019 Author Share Posted July 18, 2019 So if using individual blood tithe points, do they benefit from points generated by the other team member ( I have seen it played this way, so you can end up with 2 bloodthirsters arriving at the same time)! Quote Link to comment Share on other sites More sharing options...
0 EMMachine Posted July 18, 2019 Share Posted July 18, 2019 2 minutes ago, John E said: So if using individual blood tithe points, do they benefit from points generated by the other team member ( I have seen it played this way, so you can end up with 2 bloodthirsters arriving at the same time)! This should be possible after Blood Tithe points are generated when a unit is destroyed. So each Khorne player get's a point when a unit get's destroyed. As a sidenote, its the same for Tzeentch after they get Fatepoints for each casted spell (friend or foe). So these two summons get particularly in multiplayergames. Quote Link to comment Share on other sites More sharing options...
0 Mikeymajq Posted July 18, 2019 Share Posted July 18, 2019 You are both completely seperate armies and do not share any abilities even if they have the same name. If a unit dies you both get 1 bloodtithe point each like normal. You can't spend someone elses blood tithe etc. Quote Link to comment Share on other sites More sharing options...
-1 King Taloren Posted July 16, 2019 Share Posted July 16, 2019 @Vextol I guess the answer here is to see what your TO has to say about tithe points. Though in this situation I’m fairly certain individual pools are the way to go otherwise you could argue that the sharing rules goes even with Khorne vs Khorne games and both sides have to share the same pool of points. Why should both Khorne armies get their own individual bloodtithe pools after al? Quote Link to comment Share on other sites More sharing options...
John E
8 answers to this question
