Thiagoma Posted May 17, 2019 Share Posted May 17, 2019 Is the banner a freebie like the banners in units? When assembling the model, the flag goes into the weapon hand, making the offhand hold a shield or a bow. In thos case the noble uses the weapon i choose regardless of the equiped one? aos-warscroll-dragon-noble-en.pdf Quote Link to comment Share on other sites More sharing options...
flamingwalnut Posted May 19, 2019 Share Posted May 19, 2019 This has the same "issue" as the Free Guild General, in that the banner is a "free" item. Because it does not say you take the banner or something else, like the wording between the shield and the bow, then it does not conflict with any other item he has. NOW, how to MODEL the Dragon Noble is a bit of a problem. As the model is, he DOES have to not take something, but if you build him "optimally" as his warscroll allows he should have: A sword/polearm (lance if on a horse), a shield/bow, and a banner. So, a loadout can be polearm, shield, banner, all at once. How you model that is up to your imagination. I like to do the back banner effect, where you just put it "attached" to their back, kind of like many Samurai styles. Quote Link to comment Share on other sites More sharing options...
Thiagoma Posted May 19, 2019 Author Share Posted May 19, 2019 My plan is to have it stuck on the ground, with the noble riding a Lion 1 Quote Link to comment Share on other sites More sharing options...
dekay Posted May 19, 2019 Share Posted May 19, 2019 Technically the only option you can assemble without conversion is starblade, with sword in scabard. But banner stuck in the ground resolves the issue nicely ; ) Quote Link to comment Share on other sites More sharing options...
