darranh1 Posted April 8, 2019 Share Posted April 8, 2019 Casting range to buff friendly units. Do all the models of that unit have to be within range or just 1? I have same thoughts on spell that inflict mortal wound but I’m assuming if the closest model of unit in range whole unit has to be affected. Thanks Quote Link to comment Share on other sites More sharing options...
2 The Golem Posted April 8, 2019 Share Posted April 8, 2019 If the ability says 'a unit within X" ', then you only need 1 model from that unit to be within X". If the ability says 'a unit wholly within X" ', then you need every model from that unit to be inside the X" radius and the bases mustn't cross the limit. 1 1 Quote Link to comment Share on other sites More sharing options...
darranh1
Thanks
1 answer to this question
