States Posted February 10, 2019 Share Posted February 10, 2019 So my Thanquol came with a 90mm oval base. I checked the offical base faq and it states it should be 105mm oval. On the GW site, the Thanquol is also listed with 90mm oval.. Same thing happened to the doomwheel, it is now on the site with a 90mm but the faq says 105. Which is correct? are they changing stuff again? Link to comment Share on other sites More sharing options...
NemoVonUtopia Posted February 10, 2019 Share Posted February 10, 2019 I was wondering the same thing. The one I got was old so it only came with a square base so I'm glad for confirmation that getting a 90 oval wasn't flat out wrong. Link to comment Share on other sites More sharing options...
Overread Posted February 10, 2019 Share Posted February 10, 2019 For bases its normally good to let the Battletome land - confirm things in the online FAQ and then wait a bit to get GW confirmations. They have chagned bases in the past only to realise they've made mistakes and gone back to adjust them. Link to comment Share on other sites More sharing options...
