I had a game with my stormcasts against my friend's khorne army where his bloodletters managed to kill all my sequistors but I did deny the final wound to allocate with the Cycle of the Storm ability from the lord arcanum, leaving one sequistor alive. My friend claimed that he should still get a bloodtithe point because the unit was technily slained if we look at the wording in Cycle of the storm ability:
Quote
"once per turn, when a friendly Stormcast Eternal model is slain within 18", instead of removing the slain model, you can heal 1 wound allocated to it..."
It implies that the model is considered slain before being prevented to be removed so I conceded and let him have the bloodtithe point because the last sequistor of the unit was indeed slain by the last wound (and thus the unit before the Cycle of the Storm ability takes effect.
However I have read the designers'commentary where it says:
Quote
Q: If I use the Lord-Arcanum’s Cycle of the Storm to heal a wound on a model instead of slaying it, what happens to any wounds that remain to be allocated? A: Continue to allocate them as normal. Cycle of the Storm will not always stop a model from being slain, but will require an extra wound to be inflicted in order to do so.
It implies that a model could stop from being slain, which means that in the previous situation the bloodtithe point should not have been counted as the model was prevented to be considered slain (and as such the unit) but simply ignore the last wound to be allocated.
It seems to me there are two different vision of Cycle of the Storm out there at the moment but I don't know which one should be considered.
What do you guys think ? What would you have done in my situation ?
Sigmarusvult
Hey guys,
5 answers to this question
