Carnivore Posted January 7, 2019 Share Posted January 7, 2019 Hi there! A player ran into an issue and I would likt to adress that, by asking you here. The question is: Can I reroll charge rolls for ONE units multiple times by using multiple command points? The rules stated, that a modifier can not be applied multiple times, as it is only allowed to modify an existing roll ONCE. What do you guys think? Cheers/// Quote Link to comment Share on other sites More sharing options...
1 Isotop Posted January 7, 2019 Share Posted January 7, 2019 @BaldoBeardo is absolutely right. From the Core Rules: "Some rules allow you to re-roll a dice roll, which means you get to roll some or all of the dice again. If a rule allows you to re-roll a result that was made by adding several dice together (e.g. 2D6, 3D6 etc.) then, unless otherwise stated, you must roll all of those dice again. You can never re-roll a dice more than once [...]" (Page 1 under RE-ROLLS) So yes, you can use Forward to Victory a second time on the same unit - but you will not be allowed to re-roll the charge roll again (so do not use it a second time ^^) Quote Link to comment Share on other sites More sharing options...
0 BaldoBeardo Posted January 7, 2019 Share Posted January 7, 2019 2 minutes ago, Carnivore said: Hi there! A player ran into an issue and I would likt to adress that, by asking you here. The question is: Can I reroll charge rolls for ONE units multiple times by using multiple command points? The rules stated, that a modifier can not be applied multiple times, as it is only allowed to modify an existing roll ONCE. What do you guys think? Cheers/// You can't reroll a reroll. Regardless. 2 Quote Link to comment Share on other sites More sharing options...
0 Carnivore Posted January 7, 2019 Author Share Posted January 7, 2019 Alright, thank you very much Quote Link to comment Share on other sites More sharing options...
Carnivore
Hi there!
The question is:
Cheers///
3 answers to this question
