MadCat Posted September 30, 2018 Share Posted September 30, 2018 Hi All, i'm new in AoS and i have a question with the dispel endless Spell rules. Can a wizard Dispel Endless Spell from the battlefield and re-cast the same Endless, in the same turn? Please help me Thank You Quote Link to comment Share on other sites More sharing options...
2 Overread Posted September 30, 2018 Share Posted September 30, 2018 Yes. Dispelling an Endless Spell happens at the start of the turn phase and each wizard can attempt to dispel one Endless spell per turn. Doing so will use a casting slot for the wizard, so any wizards that can only cast one spell per turn won't be able to cast any others after attempting a dispel (whether it works or fails). However if your wizard can cast more than one spell per turn they can dispel and then cast the same Endless spell without issue. The only restriction is really that in matched play, you can only cast one of any type of Endless spell at the same time. 1 Quote Link to comment Share on other sites More sharing options...
0 MadCat Posted September 30, 2018 Author Share Posted September 30, 2018 Thank You Bro. ✌️ Quote Link to comment Share on other sites More sharing options...
MadCat
Please help me
Thank You
2 answers to this question
