The Sylvaneth Wyldwood warscroll announces the following:
Quote
Roll a dice for each model that makes a run or charge move across, or finishing on, a Sylvaneth Wyldwood.
Emphasis mine.
In the Age of Sigmar Core Rules Movement Phase section, the following is genteelly stated:
Quote
If the warscroll for a model says that the model can fly, it can pass across models and terrain features as if they were not there when it makes any type of move.
Which rule takes precedence here? On the one hand, flyers moving across a Wyldwood are, regardless of position, technically moving across the terrain feature. On the other, they behave as if the terrain piece was not there. On the one hand, warscrolls take precedence over core rules. On the other, the core rules are more recent.
As a non-Sylvaneth player, you can probably guess which side I come down on, but I'd sure appreciate some other input!
Kirjava13
Emphasis mine.
3 answers to this question
