hudiniq Posted August 30, 2018 Share Posted August 30, 2018 Hey all. A quick question. If I have a unit of 5 liberators, where the prime has no shield but a grandhammer. How do i roll saves? Can i still reroll ones? The attacks I make separate, right? Quote Link to comment Share on other sites More sharing options...
1 BaldoBeardo Posted August 30, 2018 Share Posted August 30, 2018 16 minutes ago, hudiniq said: Hey all. A quick question. If I have a unit of 5 liberators, where the prime has no shield but a grandhammer. How do i roll saves? Can i still reroll ones? The attacks I make separate, right? You get to reroll saves as long as any model in the unit has a shield. Also bear in mind you don't allocate wounds/remove models until all attacks have been resolved. 1 Quote Link to comment Share on other sites More sharing options...
0 hudiniq Posted August 31, 2018 Author Share Posted August 31, 2018 Ok, that's cool. So even if I have a unit of 2 left, where only 1 has a shield and I get 2 saves of one, I can still reroll both? Quote Link to comment Share on other sites More sharing options...
0 stato Posted August 31, 2018 Share Posted August 31, 2018 39 minutes ago, King Taloren said: Yes since all casualties are removed at the end of your opponents attack activation you reroll any 1s until the shield model actually takes the damage and is slain To expand on that, casualties are removed at the end of a units attacks, so even if you take 2 wounds from some weapons which is enough to kill the shield guy, he hangs around (giving you the re-roll) until all other attacks from the enemy unit are completed. Quote Link to comment Share on other sites More sharing options...
0 hudiniq Posted August 31, 2018 Author Share Posted August 31, 2018 Nice..so practically you remove the models at the end of an "encounter", so to speak. Thanks all! This clarifies a lot. Quote Link to comment Share on other sites More sharing options...
-1 King Taloren Posted August 31, 2018 Share Posted August 31, 2018 Yes since all casualties are removed at the end of your opponents attack activation you reroll any 1s until the shield model actually takes the damage and is slain Quote Link to comment Share on other sites More sharing options...
hudiniq
5 answers to this question
