Fluttershy Posted July 5, 2018 Share Posted July 5, 2018 Crusading Army: You can re-roll run or charge rolls for friendly FLESH-EATER COURTS units. At the Double: You can use this command ability after you make a run roll for a friendly unit that is within 6" of a friendly Hero, or 12" of a friendly Hero that is a general. If you do so, the run roll is treated as being a 6. Is it possible to use a command point on At the Double after re-rolling a (crusading army) run roll? Link to comment Share on other sites More sharing options...
Honk Posted July 6, 2018 Share Posted July 6, 2018 Why not?! You can only reroll once, but at the double says „treat it like“ so if you really need that run to happen, you could. on the other hand, you cannot use „forward to victory“ because that would be a second re-roll Link to comment Share on other sites More sharing options...
Fluttershy Posted July 16, 2018 Author Share Posted July 16, 2018 actual FAQ states: Q: Some abilities allow you to either pick, change or replace a dice roll with the roll of your choice. Does this happen before or after any re-rolls or modifiers? A: Unless noted otherwise in the ability, it happens before any re-rolls or modifiers are applied. does this apply to the command ability? Link to comment Share on other sites More sharing options...
Inqy Posted July 17, 2018 Share Posted July 17, 2018 2 hours ago, Fluttershy said: actual FAQ states: Q: Some abilities allow you to either pick, change or replace a dice roll with the roll of your choice. Does this happen before or after any re-rolls or modifiers? A: Unless noted otherwise in the ability, it happens before any re-rolls or modifiers are applied. does this apply to the command ability? FAQ says "unless noted otherwise", the text for At The Double specifically notes that it happens *after* the roll. Link to comment Share on other sites More sharing options...
Fluttershy Posted July 17, 2018 Author Share Posted July 17, 2018 3 hours ago, Inqy said: FAQ says "unless noted otherwise", the text for At The Double specifically notes that it happens *after* the roll. but it says "before any re-rolls or modifiers are applied. " and Crusading Army ability applies a re-roll to the hit roll i guess after the re-roll of the run roll "At the Double" can't kick in anymore Link to comment Share on other sites More sharing options...
Honk Posted July 17, 2018 Share Posted July 17, 2018 1 hour ago, Fluttershy said: but it says " unless noted otherwise... it is noted otherwise, the notation says : after... if the one rule states: reroll run and charge, and the other rule states: you can choose to count your run roll as a 4 ( or charge as a 6 (like some banners did), then no certain order or sequence is given. This leads to the normal 1. set dice 2. reroll 3. modify sequence... this is how I would read it ??♀️ Link to comment Share on other sites More sharing options...
Fluttershy Posted July 17, 2018 Author Share Posted July 17, 2018 ok, makes sense thank you ? Link to comment Share on other sites More sharing options...
Honk Posted July 17, 2018 Share Posted July 17, 2018 7 hours ago, Fluttershy said: makes sense ...wellllll... sometimes I‘d love to have them write simple comprehensive rules, not things where your inner rule-lawyer cringes and gives a wobbly thumbs up Link to comment Share on other sites More sharing options...
