GingerGiant Posted November 3, 2017 Share Posted November 3, 2017 Howdy, folks! This is a guide to show you how to get the most out of your Start Collecting: Seraphon box. I believe the ideal number of these boxes to purchase is 2, in order to minimize the number of unusable models (following Matched Play unit composition rules) from the Knights and Warriors units. However, if your opponents dont mind you paying points-per-model, instead of the increments listed in the General's Handbook, you'll likely be perfectly fine with a single box. With two boxes, you get a solid mix of different units to build, which you can mix and match for 1000 point games. When I use the phrase "full command," it refers to having three models in a unit representing a single leader (Alpha), standard-bearer (Stardrake Icon), and musician (Wardrums). This terminology comes from Warhammer Fantasy Battle. Sprue Breakdown ...for one Start Collecting: Seraphon box. Carnosaur/Troglodon 1 Carnosaur/Troglodon sprue, which is used to assemble the majority of the Carnosaur or Troglodon. 1 Carnosaur/Trogolodon "Riders" sprue, which contains bits for the Saurus Oldblood, Saurus Scar-Veteran, and Skink Oracle. It comes with an additional set of legs for the Saurus Rider to be assembled "on foot". You can find parts of the Troglodon's collar and the back spines on the sprue as well. There are several weapons options and decorations on this sprue, some of which are for units that no longer exist in Age of Sigmar. There are lots of good bits on this sprue for decorating and conversions. If you use the sprues to build a Saurus Oldblood or Scar-Veteran on Carnosaur, you will have leftover bits with which to convert a Skink Hero of some kind. I recommend a Skink Starpriest, as I think he's very useful with the units you will have from Start Collecting: Seraphon. You can also magnetize the Saurus rider to switch between the Saurus Oldblood and Scar-Veteran. I recommend modeling the Saurus rider with armor. If you use the sprues to build a Troglodon, you will have leftover bits with which to create a Saurus Hero on foot. I found this handy guide which explains how to create a Saurus Hero on Foot. With the amazing power of magnets, this Saurus Hero can represent either a Saurus Oldblood or Saurus Sunblood. Saurus Warriors 3 Saurus Warriors Club sprues, which have the bodies, legs, club-wielding arms, shield arms, and shields. 3 Saurus Warriors Spears & Command sprues, which has the heads, spear-wielding arms, banner-wielding arm, two banners toppers, arm holding a drum, arms holding mallets,s. With the bits provided, for each 4 Saurus Warriors you assemble, one model may be assembled as an Alpha Talon, one model may be assembled to carry a Stardrake Icon, and one model may be assembled to carry Wardrums. If the minimum size of a unit of Saurus Warriors was 4 models, you could build three 4-model units, each with full command, from a single Start Collecting: Seraphon box. You are not forced to assemble any Saurus Warrior as a Alpha Talon, Stardrake Icon-bearer, or Wardrummer. As an alternative to Saurus Warriors, you can convert their weapons into polearms by snipping the heads off of the spears, and attaching the heads of the clubs. Tell your opponents they are Saurus Guard. Only 3 of the clubs resemble the polearms from Saurus Guard, so you may look to other bits for an appropriate polearm head. I recommend painting converted Saurus Guard with faded scales/skin to look older and more weathered than Saurus Warriors or Saurus Knights. For Matched Play, these sprues provide enough parts to assemble a 10-model unit of Saurus Warriors with full command. Two Saurus Warriors will be left over. If you make the Saurus Guard conversion, you can assemble two 5-model units of Saurus Guard with full commands, or one 10-model unit of Saurus Guard with full command. Two Saurus "Guard" will be left over. Saurus Knights 2 Saurus Knights Lance sprues, which have lance-wielding arms, the banner-wielding arm, banner accessories (including toppers), shield-carrying arms, wardrums, some club-wielding arms, an alternative head for the Alpha Knight's mount, and some decorations. 2 Saurus Knights body sprues, which contain the Saurus bodies, remaining club-wielding arms, Saurus heads, including an additional head with which to indicate the Alpha Knight, and some decorations. 8 Cold One sprues, each of which contains all the bits to assemble a complete Cold One mount. With the bits provided, for each 4 Saurus Knights you assemble, one model may be assembled as an Alpha Knight, one model may be assembled to carry a Stardrake Icon, and one model may be assembled to carry Wardrums. If the minimum size of a unit of Saurus Knights was 4 models, you could build two 4-model units, each with full command, from a single Start Collecting: Seraphon box. You are not forced to assemble any Saurus Knight as an Alpha Knight, Stardrake Icon-bearer, or Wardrummer. For Matched Play, these sprues provide enough parts to assemble a 5-model unit of Saurus Knights with full command. Three Saurus Knights will be left over. Link to comment Share on other sites More sharing options...
GingerGiant Posted November 3, 2017 Author Share Posted November 3, 2017 ...but what can you do with two Start Collecting: Seraphon boxes that you cannot do with one? I'm convinced that grabbing a second box is critical to any collection. In general, I try to play as WYSIWYG as possible. to both help me remember what I have on the table, and to assist my opponent. The second box will allow you to field a larger unit of Saurus Warriors or build more units of Guard, and gets you more bits to explore conversions. You'll be surprised how many bases you can cover, which is what I'll elaborate on below. Two-Box Optimization I'm going to approach two-box optimization from the view that I want to not only have a variety of models in my collection, but have a variety of point-costs to build lists with. I think the two boxes will serve you well, as you can have as many as 1580 points from just two boxes, or as few as as 1380, following my directions. Carnosaur/Troglodon With the sprues available, my assembly recommendations are as follows: Build one Saurus Hero on Carnosaur, magnetized to represent either the Saurus Oldblood on Carnosaur or Saurus Scar-Veteran on Carnosaur. Build one Troglodon. Build one Saurus Hero on Foot, magnetized to represent either the Saurus Oldblood or Saurus Sunblood, using the bits leftover from the Troglodon kit. Build one Skink Wizard, magnetized to represent either the Skink Starpriest or Skink Starseer Use the throne bits from the Troglodon to construct a throne appropriate to the Skink Starseer, and use magnets to attach the Skink from the Carnosaur. With a second throneless base made, it easily represents both Skink Wizards, affording you much flexibility in list buildilng. The Troglodon is the cheapest Behemoth option available to Seraphon, and I would rather have two different looking Behemoths, than two Saurus Heroes riding nearly identical Carnosaurs. I do think there is merit in having both Carnosaur variants in your collection, because there is quite a bit of synergy in their Command Abilities. But, because it's their Command Abilities that have synergy, you would have to run a Fangs of Sotek Battalion, and that's going to bring you into the 2000 point army range: it's a very expensive combo that really only comes into play against Monsters. You'll have to work your best Green Stuff Magic to get them into different poses. Hint: buff the Clawed Forelimbs with the Oldblood's Ancient Warlord Command Ability, and buff the Oldblood with the Scar-Veteran's Saurian Savagery. Saurus Warriors With the sprues available, I recommending assembling your 24 Saurus Warriors as... One 20-model unit of Saurus Warriors with Full Command. One additional Saurus Warriors Full Command made from three of the four remaining models. Swap this with three non-Command Saurus Warriors when you want to run two 10-model units of Saurus Warriors. One Saurus Astrolith Bearer from the last Saurus Warrior model, with kitbash from your now-massive Seraphon bits collection. I personally recommend clubs for Saurus Warriors. A 20-model unit will have no problem getting into close combat, and if that is proving difficult, roll out the Saurus Oldblood on Foot for a 3" 'Pile Out' in each of your Hero Phases. That will allow you to subsequently Pile In into the best position. Mind you, any model in base-to-base with an enemy cannot participate in the 'Pile Out', due to the specifications of the Paragon of Order ability. Saurus. If you decided to go the route of the Saurus Guard, you can assemble... Two 5-model units of Saurus Guard with Full Command One 10-model unit of Saurus Guard with Full Command One additional Saurus Guard Full Command made from three of the four remaining models. Swap this with three non-Command Saurus Guard from the 10-model unit to run a total of four 5-model units of Saurus Guard. One Saurus Astrolith Bearer from the last Saurus Warrior model, with kitbash from your now-massive Seraphon bits collection. I would prefer to have both Saurus Warriors and Saurus Guard in my collection, so I am inclined to go and pick up an actual Saurus Guard box, which has all the pieces you need to build exactly three 5-model units of Saurus Guard with Full Command. They're really nice looking models, too. Saurus Guard get no model-count bonuses or Horde discount, so I'm going to need a big single-unit buff to justify running them outside of minimum size units, which might encourage me to get a second Saurus Guard box to run one 20-model unit alongside two 5-model units, or three 10-model units. Saurus Knights I recommend assembling the 16 Saurus Knights as... Three 5-model units of Saurus Knights, each with Full Command, which is15 models in total. One Scar-Veteran on Cold One from the last Saurus Knight model, with kitbash from your now-massive Seraphon bits collection. Coincidentally, you can field a Firelance Starhost with just the models you assembled from the Saurus Knights. The Saurus Knights are very good in 'Multiple Small Units', as they deal enough damage on their own to outperform Saurus Warriors under 30 models, while being quite a bit faster, when you compare equivalent points costs (200 pts. Saurus Knights > 200 pts. Saurus Warriors unit for damage, but 300 pts. Saurus Knights < 300 pts. Saurus Warriors unit for damage). Link to comment Share on other sites More sharing options...
rokapoke Posted November 4, 2017 Share Posted November 4, 2017 6 hours ago, GingerGiant said: Saurus Knights 2 Saurus Knights Lance sprues, which have lance-wielding arms, the banner-wielding arm, banner accessories (including toppers), shield-carrying arms, wardrums, some club-wielding arms, an alternative head for the Alpha Knight's mount, and some decorations. 2 Saurus Knights body sprues, which contain the Saurus bodies, remaining club-wielding arms, Saurus heads, including an additional head with which to indicate the Alpha Knight, and some decorations. 8 Cold One sprues, each of which contains all the bits to assemble a complete Cold One mount. With the bits provided, for each 4 Saurus Knights you assemble, one model may be assembled as an Alpha Knight, one model may be assembled to carry a Stardrake Icon, and one model may be assembled to carry Wardrums. If the minimum size of a unit of Saurus Knights was 4 models, you could build three 4-model units, each with full command, from a single Start Collecting: Seraphon box. You are not forced to assemble any Saurus Knight as a Alpha Knight, Stardrake Icon-bearer, or Wardrummer. For Matched Play, these sprues provide enough parts to assemble a 5-model unit of Saurus Knights with full command. Three Saurus Knights will be left over. Nice write-up overall! However, you didn't fully adjust your copy-paste from the Warriors here. You could build TWO 4-model units of Knights, not three. Link to comment Share on other sites More sharing options...
GingerGiant Posted November 4, 2017 Author Share Posted November 4, 2017 14 hours ago, rokapoke said: Nice write-up overall! However, you didn't fully adjust your copy-paste from the Warriors here. You could build TWO 4-model units of Knights, not three. I’ll fix that right up now. I want to add more information on the advantages of two boxes, since every other post last night seemed to be, “I got two SC Seraphon boxes, is this good?” You can get soooo much out of two boxes! ...I just need to find some time to finish that write up. Link to comment Share on other sites More sharing options...
GingerGiant Posted November 6, 2017 Author Share Posted November 6, 2017 PSA: I finally got around to adding my two cents on assembling two Start Collecting boxes. Now, where do you go from there? Somehow, you've managed to at least assemble, if not paint, your two Start Collecting boxes. You'd like to expand your collection further. Here are my personal recommendations, organized roughly by their importance. I'm going to go out on a limb and make some strategic considerations as to why you should collect certain things before other certain things, too. Now, onto the list! One Slann Starmaster. The Starmaster is a crucial piece of any Seraphon collection. Half of the Seraphon allegiance abilities are focused on the Starmaster, and without a Starmaster, you might as well run your Seraphon as Grand Alliance: Order. Okay, maybe not, but it's really good. As I've seen others point out, a Seraphon Allegiance Starmaster has board-wide dispelling range, which goes a very long way to keeping your units safe from nasty magic (like Arcane Bolts!). Slann also make for a great General, especially when paired with an Eternal Starhost. You'll also be able to run Dracothion's Tail or the Fangs of Sotek batallions with the addition of a Slann Starmaster, both of which are very good, but you'll need to pick up a box of Saurus Warriors (or two), which is my next recommendation: One box of Saurus Warriors. A 40-model unit of Saurus Warriors requires very little support to be effective, unlike Saurus Guard (they really need an Eternal Starhost, and still vulnerable to Mortal Wounds). You can throw the Saurus Warrior Horde in any Seraphon list, and it will do wonderful things for you. I encourage you to build your Saurus Warriors, then go buy a regular Saurus Warriors box to bring the unit to 40 models, which you can also run as two 20-model units with my previous recommendations. The box of Warriors will be used to make 20 non-Command Saurus Warriors. You can pick up a second box of Saurus Warriors, to run your 40-model unit alongside two 10-model units, in a Sunclaw Starhost. The primary application being the Fangs of Sotek battalion. One Big Dinosaur of Your Choosing. There are many dinosaurs to choose from, but this one is yours. A Bastiladon is a great way to add some Mortal Wounds or long-range firepower to a Seraphon list, in addition to being very resilient. With a Great City or Grand Alliance list, there are plenty of mean buffs you can throw on it to make your opponent groan. A Carnosaur, to be your first Carnosaur's battle buddy! Do that wombo-combo to melt a monster. Or just run two Carnosaurs, because you like Carnosaurs. A Stegadon, because Stegadons can do all sorts of goofy things. I'm not very familiar with them, but they're a big dinosaur and they'll look great on the table. A Starhost of Your Choosing. You already have a Firelance Starhost. The Eternal Starhost, for those of you who want a "defensive" infantry option. If you converted your Saurus Warriors into Saurus "Guard", you need only pick up an Eternity Warden to run the Eternal Starhost. Otherwise, I think the Saurus Guard models are very nice. One box of Saurus Guard and an Eternity Warden will provide you with a basic Eternal Starhost. If you really like this battalion, pick up a second Saurus Guard box so you can maximize one of the Saurus Guard blocks (which makes it an excellent candidate for Saurus Savagery or other single-unit buffs). The Sunclaw Starhost lets your Saurus Warriors impersonate Saurus Guard. It's also a required warscroll in the Fangs of Sotek battalion. I think to get the most benefit, you really need 60 Saurus Warriors, so a 40-model unit can be accompanied by two 10-model units. Your Saurus Hero on Foot can fill in for the Saurus Sunblood, but if you really like the Saurus Oldblood like I do, you should look to either kitbashing or assembling a dedicated Sunblood. Maybe buy the bits from someone else who build a Troglodon? More is coming! But, I have run out of time again. Please, enjoy what I have written so far. Leave your comments, criticism, and advice! Link to comment Share on other sites More sharing options...
J.J Posted November 13, 2017 Share Posted November 13, 2017 Extremely good guide! I've done something very similar myself recently, but have tried to recycle a few more spare parts in there. So, my two boxes have got me: Big Monsters Oldblood on Carnosaur Troglodon Characters Scar-Vet on Cold One (using spare Knight parts) Oldblood on Foot (spare character from Troglodon) Sunblood (using spare parts from Saurus Warriors) Astrolith Bearer (spare parts from Saurus Warriors and bits from big creature sprues) Troops 20 Saurus Warriors (Full Command) 3 x 5 Saurus Knights (Full Command) I'm looking at grabbing a box of Temple Guard and using the spare parts from that to create and Eternity Warden combined with the spare Saurus Warrior bodies. I'll also investigate creating a Skink priest out of the spare Carnosaur parts too, as you suggest Link to comment Share on other sites More sharing options...
Aginor Posted November 13, 2017 Share Posted November 13, 2017 Just came here to say: This is a pretty good thread. Link to comment Share on other sites More sharing options...
GingerGiant Posted November 13, 2017 Author Share Posted November 13, 2017 1 hour ago, J.J said: Extremely good guide! I've done something very similar myself recently, but have tried to recycle a few more spare parts in there. I'm looking at grabbing a box of Temple Guard and using the spare parts from that to create and Eternity Warden combined with the spare Saurus Warrior bodies. I'll also investigate creating a Skink priest out of the spare Carnosaur parts too, as you suggest Thank you for the kind words, and that's a great idea! I would personally pick up the actual Eternity Warden model, and bulk up its tiny banners with those from the Saurus Warriors. 27 minutes ago, Aginor said: Just came here to say: This is a pretty good thread. Thank you! Link to comment Share on other sites More sharing options...
