Stormhost Triumvirate Posted August 18, 2017 Share Posted August 18, 2017 I have some small paints taht I bought and didn't fit with how I painted my armies, so I set them aside for quite a while. Would it be possible to use Citadel paints on other types of material, such as wood or clay? (I already know that painting on metal works fine because of stuff like Sisters of Battle) Link to comment Share on other sites More sharing options...
Gaz Taylor Posted August 18, 2017 Share Posted August 18, 2017 I think if you have a good undercoat you might be okay. The paints should be fine on those materials but they may need sealing as could absorb the paint rather than let it do it's job. Link to comment Share on other sites More sharing options...
RuneBrush Posted August 18, 2017 Share Posted August 18, 2017 They're just a high quality acrylic. As Gaz says you'll likely want a sealer/primer layer on most surfaces for absorbency or prevent it flaking off, but I've painted wood quite happily before. Link to comment Share on other sites More sharing options...
Stormhost Triumvirate Posted August 18, 2017 Author Share Posted August 18, 2017 Stuff like imperial primer would be fine for undercoats? Link to comment Share on other sites More sharing options...
RuneBrush Posted August 18, 2017 Share Posted August 18, 2017 14 minutes ago, Stormhost Triumvirate said: Stuff like imperial primer would be fine for undercoats? It should be, just depends entirely on what you're painting It won't be that great for something that's absorbent as Imperial Primer is a paint in it's own right. Anything like that I tend to grab a can of Plastikote Clear Sealer and whack a few layers down first. Link to comment Share on other sites More sharing options...
