Redking Posted August 14, 2018 Share Posted August 14, 2018 Crimson would go better over gold. Alternate between thinned Carroburgh and Tamiya clear. Airbrushing the Tamiya will be the best route. Link to comment Share on other sites More sharing options...
RuneBrush Posted August 14, 2018 Share Posted August 14, 2018 If you're after a cherry/candy red I'd suggest a mix of the red gem paint and carronburg crimson (bloodletter glaze might work too?). Base colour varies the end result - silvers give you a candy red and golds more of a cherry red. The FW Angron Red was a perfect paint for this, but sadly no longer in production Link to comment Share on other sites More sharing options...
SatanicBrew Posted August 14, 2018 Share Posted August 14, 2018 Thanks fo all the suggestions! I will try and see what fits best, and if I get it to work I will try to remember to post here! Link to comment Share on other sites More sharing options...
AlphaKennyThing Posted August 14, 2018 Share Posted August 14, 2018 Initial wash of watered down Carrobourg Crimson, and then use Bloodletter red glaze. Should achieve a similar effect, but red. Link to comment Share on other sites More sharing options...
SatanicBrew Posted August 14, 2018 Share Posted August 14, 2018 2 minutes ago, AlphaKennyThing said: Initial wash of watered down Carrobourg Crimson, and then use Bloodletter red glaze. Should achieve a similar effect, but red. This sounds like the best attempt at making something similar as the blue glaze in OP's post. I will try this one and see how it goes! Link to comment Share on other sites More sharing options...
Tommy Posted August 14, 2018 Share Posted August 14, 2018 There's also GW's red glaze (which is different to the crimson wash) if you're limited to GW paints as some are. The WHTV guys did a tip of the day on glazes a while back, and my own experience (with the blue glaze) is that you can deepen the tint a lot by applying more than one coat. Link to comment Share on other sites More sharing options...
AlphaKennyThing Posted August 18, 2018 Share Posted August 18, 2018 Followed a similar scheme, though added blue to the shoulders only and added some colours to heroes. Link to comment Share on other sites More sharing options...
Kramer Posted August 20, 2018 Share Posted August 20, 2018 On 8/18/2018 at 8:34 PM, AlphaKennyThing said: Followed a similar scheme, though added blue to the shoulders only and added some colours to heroes. Amazing looking armour! Link to comment Share on other sites More sharing options...
AlphaKennyThing Posted August 20, 2018 Share Posted August 20, 2018 4 hours ago, Kramer said: Amazing looking armour! Slight adaption to the OP so credit goes mainly his way! Leadbelcher Spray. Drakenhof Nightshade all over. Light drybrush of Stormhost Silver. Guilliman Glaze on the shoulder pads and shields. Paint robes black. Drybrush Eshin Grey. Light drybrush Dawnstone. Probably the quickest miniatures I've ever painted! Link to comment Share on other sites More sharing options...
polarbear Posted August 21, 2018 Author Share Posted August 21, 2018 On 8/18/2018 at 11:34 AM, AlphaKennyThing said: Followed a similar scheme, though added blue to the shoulders only and added some colours to heroes. Now that is hot! Link to comment Share on other sites More sharing options...
SatanicBrew Posted October 7, 2018 Share Posted October 7, 2018 Here is my try on the scheme. The picture doesn't do it enough justice but I am happy how it turned out, might add some more details as I go along. Link to comment Share on other sites More sharing options...
