Ratamaplata Posted April 12, 2017 Share Posted April 12, 2017 20 years ago I just used to paint the base green then flock it and that was the norm really. I see things have now changed greatly. So a few questions... - can you recommend a good YouTube tutorial on the subject including attaching the mini - how do you go about it? Make the base and mini separately then attach? Both together from the start? Something else? - is it ok to paint the mini and base then carefully superglue them together? Will the glue mess stuff up? Any other tips and advice will be appreciated Link to comment Share on other sites More sharing options...
Soulsmith Posted April 12, 2017 Share Posted April 12, 2017 Ok soi not got any youtubes, but I have seen people both paint the miniature on base then do the basing, and make both separately then attach. Personally I do the former most often, though if it isn't attached too hard I will remove the miniature when it comes to basing. Link to comment Share on other sites More sharing options...
Redking Posted April 13, 2017 Share Posted April 13, 2017 It kind of depends on what you are doing. With sand or texture paint you can glue the mini to the base, then add the basing material after you paint the mini. When using cork, slate, bark, resin bases, etc., paint them separate and pin your mini to the base. Just use a pin vise to drill a hole in each foot, superglue the pin (I use paper clips), match the pins to the base to drill the holes there, and then superglue the model. There are tons of basing videos on YouTube. Sorastro painting has easy to follow guides in his painting Imperial Assault series. Just search for pinning a model to a base. Good luck Link to comment Share on other sites More sharing options...
RuneBrush Posted April 13, 2017 Share Posted April 13, 2017 Pretty much everything I've painted has been attached to the base before being undercoated. If I'm using sand, I'll glue the model on, apply sand (sealing with a watery coat of PVA) and then undercoat. As @Redking says, superglue and a small pin is the best way if you're doing a more scenic base where the model is glued on once painted - a pillar drill stand helps to drill the base hole too. Link to comment Share on other sites More sharing options...
Ratamaplata Posted April 13, 2017 Author Share Posted April 13, 2017 Cheers dudes. I think I'll pick up a drill then Link to comment Share on other sites More sharing options...
