Sacrosanct 1000 points Advice
Murphy
Upcoming 1000 points event to start of AoS 2.0 and decided to grab the sacrosanct from the Soul Wars box a couple times to build a force for it. Wanting to run Celestial Vindicators as I love that blue armour and so far this is what I have as a list. Any advice is more than welcome.
Allegiance: Stormcast Eternals
- Stormhost: Celestial Vindicators
Leaders
Lord-Arcanum on Gryph-Charger (240)
- General
- Trait: Single-minded Fury
- Artefact: Stormrage Blade
- Spell: Azyrite Halo
- Mount Trait: Savage Loyalty
Battleline
5 x Sequitors (120)
- Stormsmite Mauls and Soulshields
- 2x Stormsmite Greatmaces
5 x Sequitors (120)
5 x Sequitors (120)
Units
5 x Evocators (200)
War Machines
Celestar Ballista (100)
Total: 1000 / 1000
Extra Command Points: 0
Allies: 0 / 200
Wounds: 66
I dont know how often i had wrote that and will write it in the future. A unit of 5 Sequitors can have 3 grandweapons. 2 for the unit, one for the prime. Look at the warscroll in gw homepage easy to build sequitors or inside the new battletome.
unit of 5 : 3 Grandmaces
unit of 10: 5 Grandmaces
unit of 15: 7 Grandmaces
units of 20: 9 Grandmaces
Leaders
- General
Battleline
5 x Sequitors (120)
5 x Sequitors (120)
5 x Sequitors (120)
Units
5 x Evocators (200)
War Machines
Total: 1000 / 1000
Allies: 0 / 200
Wounds: 66
To your list, i think its a little bit too slow, you can drop sce 9“ away now, so you need a 9“ charge. I would either go for Hammers of Sigmar Stormhos+ Gavriel(+3“charge)or Chronomatic Coggs (+2“charge).
So -1x 5 Sequitors + 1 Gavriel and you will have a very strong 1000 points list. I had Won a small event at the weekend with a list most similiar to this. ( i had 2 units evocators and no balistas)
- Stormhost: Hammers of Sigmar
Leaders
Lord-Arcanum (180)
- General
- Trait: We Cannot Fail
- Artefact: God-forged Blade
Gavriel Sureheart (100)
Battleline
5 x Sequitors (120)
5 x Sequitors (120)
Units
5 x Evocators (200)
War Machines
Endless Spells
Chronomantic Cogs (60)
Total: 980 / 1000
Allies: 0 / 200
Wounds: 60
  • 2 weeks later...
So the final version of the list saw play consisting of
Lord-Arcanum (180)
- General
- Spell: Lighntning Blast
5 x Sequitors (120)
- 3x Stormsmite Greatmaces
5 x Sequitors (120)
5 x Evocators (200)
- 2x Grandstaves
- Lore of Invigoration: None
5 x Evocators (200)
- 2x Grandstaves
Total: 980 / 2000
Extra Command Points: 20
Allies: 0 / 400
Wounds: 61
And so far is 3 for 3 on wins, mucho happy with it
  • 2 months later...
On 10/21/2018 at 4:09 AM, Desolater said:
Nice list, I’m thinking of running the list below. Don’t want to run Gav as just feel everyone is trying to get on the GavBomb and want to be a bit different. Any thoughts on this 1000 list?
(ignore the greatmace incorrectness)
I don't recommend the castigator, they don't have a very good damage output compared to the ballista and they have too few models to capture objectives. Since there are only very few points left, I suggest change the castigator to a unit of skinks, which help your slow army, in my opinion, capture objectives more easily.
Okay interesting. So what weapon config?
how many skinks? Never looked into getting them into my army
For skinks, I will go with the boltspitter and star-buckler. If you are going to use the skinks, remember that they are not used to make damage in a stormcast army. Don't expect them to do much damage. I usually use them to steal points from my opponent. Since they are fast and have a high bravery, and most importantly, they have ability to retreat up to 8' at the beginning of combat phase instead of fighting, they can just stay near the objective and outnumber your opponent for a long time if you can put them in a good position. For 1000 army, 1 unit will be enough. For a 1500 or 2000 army, I will take 2 unit.
I just realized you could use the skinks retreat rule to slingshot them onto an objective if you charge and then immediately retreat 8" you get a lot of extra movement at the expense of other units fighting second ofc.
I'll have to get 30 skinks for the tryhard lists i suppose :D i was considering dryads for cheaper bodies, but this rule nails it.
